Results 1 to 6 of 6
    Default Can some one solve my problem.Help me plz
    I have a strange problem with my CPU.When I downloaded the software of neasat 9800i, the serial port(com1&com2) stopped working.Now my serial ports are not working. I adopted many methods to solve this problem but did not. I also reinstalled the window but not.
    Can some one help me.I shall be highly thank ful to u for your this act[/img]
    go to control panel/system/device manager, and modify the settings of your serial and com port assignments. it must be that you shorted out your comports too. if that does not work, but a pci-to-serial adapter or usb-to-serial adapter.
    Default Can some one help me
    Tank u for reply.I already had done it but the result was same.When I attached the digitall world sci190m, the message was "Check condition...(D.1).Plz help me. Is it the fault of mother board? if yes lpease help me.
    I attatched the serial mouse to ths port, it also did not work. From where
    I can repare my CPU. Plz help me.
    Lahore
    Default Re: Can some one help me
    Quote Originally Posted by imtiazshah
    yes,,your M/B got faulty and its remedy is to add another IO Card to get additional serial ports
    I think Neosat is the ONLY receiver burning the ports ,,as I said in a post Satlover was facing same problem while carrying on experiments with Neosat STB.
    Fte Max 100S
    Humax IRCI-5400z
    Default Re: Can some one solve my problem.Help me plz
    dear imtiaz if this is M Board problum Get usb to serial port from computer shop if u have two serial out in ur M-b than try s2
    Pakistan
    Check your motherboard biose setting under com port adress setting.
  1. HELP NEED TO SOLVE MY PROBLEM
    By skycom in forum RDI - English
    Last Post: 17th October 2006, 03:26
  2. Replies: 2
    Last Post: 14th September 2006, 23:50
  3. Please Solve My Problem
    By Mathila in forum RDI - English
    Last Post: 16th April 2006, 22:26
  4. your help invited to solve opentel 4000CIR problem
    By chuppan in forum RDI - English
    Last Post: 6th January 2006, 19:46
  5. find somebody to solve indo TV7 problem
    By pjerry7799 in forum RDI - English
    Last Post: 6th December 2005, 11:32
