Results 1 to 3 of 3
    ash7aq
    Default gbox does not decrypt in ProgDVB and DVBViewer
    I have Pinnacle Sat HDTV Pro USB card. I have 4 LNBS working and I was trying to make gbox run on ProgDVB and DVBviewer.
    Unfortunalet I have spent more than a week now trying to figure out which gbox plugin work with which Progdvb version.
    here is my problem
    1. My DIseqC switch does not work with earlier versions than 4.8.1 I get no signal because Diseqc mode is not supported.
    2. I am able to get signal on 4.8.1 but then I can only watch FTA channels.
    3. When I put gbox plugins in the directory C:\progdvb\Plugins\ and start ProgDVB it hangs . Only Plugin on which I am able to start ProgDVB is 0.0.0.5 and 0.0.0.6 may Marrow
    4. Now I get the Signal I get the ProgDVB to work but when I start gbox which is in C:\gbox\gbox211.exe it connects and I see cards in share.info but I cannot decrypt any channel. it does not even request the peer for card.
    5. I also tried DVBviewer it can decrypt Premiere and D+ but nothing else.
    Now is there anyone who ever made Progdvb 4.8.1 or dvbviewer work with gbox?
    Which plugin of gbox did you used?
    Which file goes in which directory ? for example gbox.exe/cwshare.cfg/plugin dlls ? for both ProgDVB 4.8.1 and DVBViewer?
    Many thanks
    Wild West
    It's works verry well !
    But you done something wrong.
    ash7aq
    Quote Originally Posted by ovidiumarius View Post
    ok instead of keeping me wondering why dont you say something how it works?
