Results 1 to 6 of 6
    anjan_nur
    Default sr 4200 upload problem
    when i tried to upload the latest software the starsat 4200d receiver,
    i get the ' serial port probe error'.
    What could be the problem?
    pl. anybody can help.
    thanks.
    21.95° N 97.06° E
    Hi friend, plz. check ur cable first.
    " 李俊明 Born To Help People "
    anjan_nur
    Hi there!
    Thanks for the reply.
    The same cable works ok for the metabox recvr upload.
    so what could be the problem?
    21.95° N 97.06° E
    Quote Originally Posted by anjan_nur View Post
    Hi there!
    If so u should try with old software first and check is it ok or not.If old software is ok , try to redownload again this new software and try again.
    Hope it'll help.
    anjan_nur
    Default sr4200 upload problem
    Hi!
    Thank u very very much for the encouragement Yan.
    the problem was solved by using a new cable.
    Probably the old cable had dry points.
    thanks once again.
    21.95° N 97.06° E
    No problem brother.Nice to hear from u like that.
    Best Regards.
