    Feb 2007
    Default dream box 500 tele text problems
    I own a dreambox 500 and got a g box image 2.26 and i am noticing that when i gi into text the first number of the text is not visable and i cannot change this image any help please
    Sep 2002
    Go to "system seting" than somewere you have Tuxtxt position, or something like that. There you can modify position of the text.
    SHALOM
    Feb 2007
    Default thanks
    i will have a go mate and thaqnks for your replay
    Banned
    Mainmenu > Setup > System settings > OSD Settings > TuxText position
    Feb 2007
    Default will not work
    i have tried it but it does not work . I think with the image i got that of g box 2,26 this feature does not work and cannot f=change this image due to c*** S*****
    Feb 2007
    Default problem solved
    with all your help I managed to solve the problem thanks to all
    Banned
    Try again , doesn`t count if you have or not CS .
    After setting the margins press green (Save)
    Feb 2007
    Post thanks *********
    thanks n*********
