    Feb 2007
    Default Problem Configuring Samba on 7020
    Not sure if in the right thread/forum or not.
    I know this was asked several times but the information is not helping me..
    Setup:
    DM 7020
    Gemini 3.30
    Necamd 6.10
    Camd3.881a
    I have the DB for 2-3 weeks now. When I got the DB it had the orginal image on it (ENigma) and I used to browse to the device using \\192.168.0.220 and play the recordings from there. With the new image Gemini 3.30 this is not an option. If I type in \\192.168.0.220 I get network cant be found. If I type in \\192.168.0.220\root apopup box appears but I dont know the username or password. Ive tried usernames like root, dreambox, gemini and passwords like none, db, root, admin, dreambox etc.
    Is this an ftp login to the root.
    I can telnet, ftp or Http to 192.168.0.220 no problem but I want to be able to play files from DB not download with FTP to pc and play. firstly can SAMBA work for the db 7020 with gemini 3.30, i have tried it but no go, this is what I did.
    I downloaded samba.tar.gz from http://dreambox.gamesquad.nl/download/samba.tar.gz. I then FTP'd the file to /var/tmp.
    I telneted into the DB to /var/tmp and entered gzip -dc /var/tmp/samba.tar.gz | tar xf - .
    I rebooted the box but still could not browse to \\192.168.0.220.
    I checked the PS and neither smbd or nmbd were running. I ran them manually from telenet with no errors and still no access.
    I also manually installed the files from the zip to the locations and set the permissions on them to read and execute.
    I'd like to get this feature working and would appreciate any help.
    DFDREAM
    Sep 2006
    Did u even touched samba.cfg?))
    Feb 2007
    Sorry DJPETER.
    I was using the information on this link.
    http://www.sat-industry.net/forums/a...hp/t-5033.html
    There is no reference to samba.cfg on this link.
    I am trying to piece the information from a couple of sites to complete this.
    I would appriciate any help you could give.
    Step by step instruction for the gemini 3.30 image.
    Where do I get the samba.cfg file and what do I do with it.
    I also notice that the libnsl.so and libnsl.so1 files have zero size is this correct. I downloaded it from.
    Thanks
    Dfdream
    Feb 2007
    I also found this link.
    But it doesnt help.
    http://www.satellites.co.uk/satellit...e/t-53813.html
    I created a file called smb.conf and added this text:
    [global]
    log file = /hdd/log/log.%m
    socket options = TCP_NODELAY SO_SNDBUF=8192 SO_RCVBUF=8192
    netbios name = Dreambox
    server string = Dreambox
    username map = /etc/user.map
    guest ok = yes
    guest account = root
    encrypt passwords = yes
    password server = none
    security = share
    interfaces = 192.168.0.24 (I changed this to the IP address of the box)
    workgroup = ork (I changed this to my workgroup)
    debug level = 0
    os level = 0
    [hdd]
    comment = HDD on Dreambox
    writeable = yes
    path = /mnt/hdd
    guest ok = yes
    browseable = yes
    valid users = root, nobody, rioh
    allow hosts = 192.168.0.
    [root]
    comment = Root on Dreambox ( Attention ! )
    path = /
    writeable = yes
    guest ok = yes
    browseable = yes
    Is there any thing else i should change.
    Even though I installed samba on the DB usiing the samba.tar.gz file the smbd and nmbd dont appear in ps even after reboot.
    If I start them manually with smbd -D and and nmbd -D and check ps again they are not there either.
    Is there little experience in this samba stuff there is nothing on the net of any value on it. Why is it not instalable as a plug in.
    Surely someone has it worked out.
    I see lots of questions about setting it up on Gemini but no answers.
    Confused
    DFDREAM
    Feb 2007
    All,
    I managed to get the SAMBA working.
    I downloaded the file from www.i-have-a-dreambox.com.
    Copied it to dreambox and installed it with blue button.
    I had to edit the smb.conf with my network settings.
    I ran the smbd -D and nmbd -D from telnet and the dreambox was then browsable.
    I use it to edit movies.
    Thing is that the setting is gone after rebooting.
    Is there an equivalent autoexec.bat file like in DOS.
    If so what is it and how is it done.
    I want to run smbd -D and nmbd -D from bootup of the dreambox.
    DFDREAM
