Page 3 of 82 FirstFirst 123451353 ... LastLast
Results 31 to 45 of 1228
  1. #31
    Jan 2003
    Italy
    Default for Masood
    But what does it mean CAS#:Nagra Aladin test, ****** 2 test, cryptoworks test? Thank you again
  2. #32
    Lahore
    Default Re: for Masood
    Quote Originally Posted by spot1bay
    But what does it mean CAS#:Nagra Aladin test, irde*o 2 test, cryptoworks test? Thank you again
    The decoding of those encryption is under progress,,,I think so,,,may be I'm at wrong.
    Fte Max 100S
    Humax IRCI-5400z
  3. #33
    Humax 5400Z user Master
    Aug 2004
    hello, I have uploaded toh3.3 hot 5.2 ....i get polsat , but don't get xxl, multivision. what should i do?
  4. #34
    Lahore
    You are missing viaccess keys,,,try to download new file into your STB.
    http://www.mach1.ws/showthread.php?t=7
    Fte Max 100S
    Humax IRCI-5400z
  5. #35
    Sep 2002
    Pakistan
    Hi Masood,
    Can u guide that which macro table is best for hummy?
    Bagram
  6. #36
    Lahore
    Quote Originally Posted by bagram
    Hi Masood,
    Bagram
    You may install any latest PMCT in your box..
    Click Mefor PMC Table.
    Fte Max 100S
    Humax IRCI-5400z
  7. #37
    Sep 2002
    Pakistan
    Hi Masood,
    PMCT and macro tables are two different things. So if u have any knowledge about macro then pls.
    Bagram
  8. #38
    Sep 2002
    Pakistan
    Hi Masood,
    Bagram
  9. #39
    Lahore
    Hi Masood,
    Bagram
    sorry begram ,,,I will reply you after have a lot of study,,,by the way you may share your knowledge plz.
    Fte Max 100S
    Humax IRCI-5400z
  10. #40
    Sep 2002
    Pakistan
    As per my humble knowledge, macros are just like small programs or commands to autoupdate some commonly used functions of humax, these cammands can be developed easily, some experts have already developed macro tables that can be downloaded to hummy with hu 1.5, the latest macro table is " MacroTable ToH3.3 - v5.35OldStyle".
    Bagram
  11. #41
    Aug 2004
    hi,
    I get only 3 blinking dots on my front panel. this happed when i tried to search for a new frequency....it said...saving...and the screen..froze. i tried hnfsmart....i can read the data...but was not able to write to the receiver. i even tried formulav3....but same result. it says " E - id " . any help will be highly appreciated. thanx
  12. #42
    this happens to me one time. i just only use this software for awakir the delete patch and delete channels. you need to do this to install again the original software of your humax and then the patch afterwards the channels
  13. #43
    Lost Ice Cap of Kilimanjaro
    Default khiladi007, "3 blinking dots only" on Humie 5400
    If when you power up your Hummi it swiftly displays H.2.08, rE and then blinks the 3 green dots only, here is what happened:
    Your Hummi lost the channel settings.
    Here is what you do to get it back healthy:
    1. Power off (main switch back panel)
    2. Load your channel setting into Humbox 4.1 (or similar) and execute "PC to Humax" (now waiting for Humax action)
    3. Switch on the Humax on back panel main switch
    Now the channel settings upload normally and you only need to upload the key.bin and everything is back to a normal happy Hummi life again. Voila!
    Taro
  14. #44
    U-A-E
    hello // khiladi007
    E ID means Invalid system ID
    check your system ID
    mr sattar
    please help to all here,,,, take care
  15. #45
    Aug 2004
    Thanx for the help i was trying to upload channel settings from hnfsmart......i identified my stb as 5400z ....it did not respond...then i identified it as 5400 .....my stb is back to normal.
  1. HUMAX IRCI 5400Z
    By sali.bangash in forum RDI - English
    Last Post: 9th November 2006, 22:02
  2. Cyfra+ fixed on Humax IRCI-5400/5400z
    Last Post: 23rd April 2006, 01:12
  3. Can for Humax IRCI 5400Z
    By bigcharlie in forum RDI - English
    Last Post: 26th February 2006, 02:03
  4. HUMAX IRCI 5400Z Help
    By jamshed81 in forum RDI - English
    Last Post: 24th September 2005, 13:26
  5. Humax IRCI-5400Z
    By Anonymous in forum SD Receivers
    Last Post: 2nd December 2004, 13:25
