Page 2 of 82 FirstFirst 12341252 ... LastLast
Results 16 to 30 of 1228
  1. #16
    Sep 2004
    SunshineState,Australia
    Default Why-upgrade
    I feel amased that members load new software to a normal working Digital Receiver.WHY.?
    Why load a new version when it is working properly.
    As I have been advised, why fix it when it is working efficiently.
    A Satellite hobbist will only do it when the new software will improve the functions, and make it work better.
    I have been advised that when u load a new software, always save the old software so that if the new loaded softwares works funny, u can go back to the old saved software.
  2. #17
    Lahore
    Default Re: Why-upgrade
    Quote Originally Posted by JPS
    I'm always crazy to download a newer version rather it made my STB abnormal I have just downloaded a new file and I want to check it within no time ,,,whereas I upgraded my Humax with latest s/w last day and I'm quite satisfied with that s/w but I'm interested to check this s/w too.
  3. #18
    Lahore
    Default The procedure how to upgrade Humax 5400 ,5400z
    To be able to enjoy your Humax, you need :
    1) a null modem cable
    2) the Humax Toolbox
    3) the latest Firmware
    4) the latest Settings
    5) the latest PMC Table
    6) the latest Keybin
    Item 1) null modem cable - you have to buy and is very cheap to get (or you can build one by yourself)
    Items 2) to 6) are luckily always available free on this Forum.
    To be able to perform items 3 to 6 mentioned above you always need the Humax Toolbox referred to at item 2 above so start by downloading it to your PC
    Then just follow this quide here of how to perform items 3 to 6 successfully starting with item 3)
    How to upload the latest firmware
    Requirements :
    Humax Toolbox
    +Cam Firmware Hot Emu xx (with extension HDF) Unzipped File
    Null Modem Cable attached between PC and Receiver
    1. Put Receiver on a FTA Channel and put it in Standby position (ensure to put in ON or STANDBY position always from the Receiver itself and not with Remote)
    2. Connect PC to Receiver with RS 232 Null Modem Cable
    3. From the Humax Toolbox select and start the Humax Uploader Version 2.O Program (you can also use HDFSmart).
    4. Set up the correct Com Port
    5. Click Open File
    6. Double Click on File Name
    7. An Information Screen pops up saying “File is unknown. Install at your own risk”’
    8. Click OK
    9. Click Upload (PC->STB)
    10. Turn On Receiver from Standby position. At this point, a progress bar appears on PC and a simultaneous one on the TV screen
    11. When download is ready, on the TV screen you will see: “End. Press Standby Key”
    12. Press Standby Key on your receiver.
    13. Then with the Remote select: Menu, Toh, Config (CAID Preselect) and select Card+Emu (vide Note 15 below)
    14. Patch is complete
    15. The following options (found under CAID Preselect) and their meanings are set out below for information and guidance:
    CARD+EMU => For Emulator DEFAULT use + ****** (2) card (fast zap)
    CARD+EMU+S => For Emulator + Card Sharing (Premiere + Irdeto2)
    CARD+S+EMU => For Emulator + Card Sharing (Premiere + Cryptoworks)
    CARD+S+EMU also support CAM with Conax card in EMU mode (slow zap)
    CAS1 => For Emulatorek/Wallbanger auto switch
    CAS2 => For Nagra Aladin test
    CAS3 => For people with SkyCrypt and Conax supported CAM's
    CAS4 => For people with Nagra supported CAM's or ****** 2 test
    CAS5 => For Cryptoworks test
    CAS6 => For SHL test
    16. Having done this, you now need to proceed to item 4)
    How to upload the latest Channel List
    1. Save the latest unzipped Settings File in the Folder of your choice
    2. Connect your PC and Receiver by RS- 232C Null Modem Cable
    3. Put your Receiver on a FTA Channel
    4. Open Humax Toolbox
    5. Select the Channel Editor Humbox V 4.1 Program (you can use also HNFSmart).
    6. On the Humbox V 4.1 Program, click on `File` and `Open`
    7. Then select and double-click on the saved unzipped file referred to at 1 above
    8. Your PC screen now displays the details of the new Channel Settings
    9. Go to Edit and Options and select the correct Com Port and Press OK
    10. Go again to Edit and Options, then to Model, type your System ID (if you don’t know or forgot your System ID, with your Remote Control go to Menu, Installation, Status and STB Status and you’ll find it listed there) and press OK
    11. Go to IRD and press on `Download to Humax`
    12. At this stage, a message pops up: Waiting for Humax Connection
    13. Press the Standby button on your Receiver to turn it to On position.
    14. The download starts immediately. Now wait for the Channel List to be downloaded.
    15. When ready, put Receiver in Standby position
    16. Put Receiver in On position
    17. Now the new Channel List is downloaded.
    18. Go to Menu, ToH and press on Config, then choose CAID
    Preselect and select Card+Emu
    Next step is to proceed to item 5)
    How to upload a PMC Table
    1. Save the latest unzipped PMC Table File in the Folder of your choice
    5. Select the PMC Tool Program
    6. On the PMC Tool Program, click on `File` and `Open`
    8. Your PC screen now displays the details of the new PMC Table
    9. Go to Config and select the correct Com Port
    10. On the same screen, press STB and Download
    11. At this stage, a message pops up: PC to STB “Waiting for Humax Connection”
    12. Press the Standby button on your Receiver
    13. The download starts immediately. Now wait for the PMC Table to be downloaded to your PC
    14. When ready, put Receiver in Standby position
    15. Put Receiver in On position
    16. Now the new PMC Table is downloaded.
    17. Go to Menu, ToH and press on Config, then choose CAID Preselect and select Card+Emu
    and finally item 6)
    Uploading the Key.Bin
    Requirements:
    FunCard (programmed with any 6in1 file) inserted in embedded slot of Receiver
    RS-232C Null Modem Cable
    Humax Toolbox
    Latest KeyBin File
    1. Save the latest unzipped Key.Bin File in the folder of your choice.
    2. Connect your PC with Receiver by RS-232C Null Modem Cable
    3. Start your Humax Receiver on a FTA Channel
    5. From Toolbox, select Samy_Humy_Edit v.1.0.0 Program
    6. Select correct Com Port
    7. Click on the folder icon, and then select and double-click on the unzipped Key Bin File referred to at (1) above
    8. Press Write Data (icon with a red lightning)
    9. At this stage, the download starts immediately and only takes a few seconds to complete.
    10. When download is ready, put Receiver in Standby position (from the Receiver itself)
    11. Put Receiver in On position (again from the Receiver itself)
    13. Go to Menu, ToH and press Config, then choose CAID Preselect and select Card + Emu
    14. Keys are now successfully installed.
    NOTHING FURTHER IS REQUIRED BECAUSE AT THIS STAGE YOUR HUMAX IS FULLY OPERATIONAL WITH THE LATEST FIRMWARE FOR YOUR ENJOYMENT
    special thanks to gimecsa
    Fte Max 100S
    Humax IRCI-5400z
  4. #19
    Lahore
    Default Polsat gone
    Polsat is not working with IRCI 5400z ToH 3.3,HoT5 ver.B since last day
    Fte Max 100S
    Humax IRCI-5400z
  5. #20
    Lahore
    Default Thanks to Gastapoo
    Dear Friends,
    You can Add new Sat & Tp using SetEditOAKV3_43 & humbox41_win9x_2k_xp Available on
    Tux on Humax site
    GASTAPOO +923336447374
    Fte Max 100S
    Humax IRCI-5400z
  6. #21
    ISLAMIC REPUBLIC OF PAKISTAN
    Hi All,
    Yes
    BEST Regards,
    GLOBAL MODERATOR
    P4 2.8GHZ 512MB 120GB HDD
    HUMAX5400Z-Dream BOX7008S-Metabox-M R2.025 Super Joker -FUN Programer Dynamite programmer-Multipro2001XL 3Dish Fixed 1 Dish World System5LNB on Single Dish Specialist in c++
  7. #22
    Lahore
    Thanks for joining Gastapoo ,,,I found the SetEditOAKV3_43 file from
    http://byksat.kabel1.cz/humax/humax.html (pm'd by majidjan from
    http://www.humax-zone.tv/forum)
    Fte Max 100S
    Humax IRCI-5400z
  8. #23
    Lahore
    Fte Max 100S
    Humax IRCI-5400z
  9. #24
    Lahore
    Fte Max 100S
    Humax IRCI-5400z
  10. #25
    Lahore
    PMCT files updated.
    Fte Max 100S
    Humax IRCI-5400z
  11. #26
    Lahore
    ToH3.3_HoT5.2 Full Patch_PL
    -All updated : 05-06-2005
    hdfbin-1-100000 -ToH3.3 - kolory -TIKI
    hdfbin-1-140000 -PMCTable
    hdfbin-1-150000 -Macro Table :
    -'mute' for QME5400 module
    -'Blue' for SuD_Catone
    -'Yellow' for HKEv1.1
    hdfbin-1-160000 -QME5400 module
    hdfbin-1-170000 -EPG Module
    hdfbin-1-180000 -RAM Edytor
    Sturm und Drang presents ver.2.0 gamma
    CATONE Conditional Access Tool ONE
    All in one CAT, PMT parser
    Ecm and DW viewer
    Raw viewer and Editor
    Special thanks to ToH Team and humax-zone.net
    ToH3.3_HoT5.2 Fully updated
    Fte Max 100S
    Humax IRCI-5400z
  12. #27
    Sep 2004
    Default Recviers Softwaer
    ---------------Software for Premium X -------------------
    Upload-download tool (new)
    http://www.satworld.gr/Premium-x/UpDown_v1.22.zip
    Settings Editor
    http://www.satworld.gr/Premium-x/Channel%20Editor_V2[1].10.zip
    Settings 09/02/05
    http://www.satworld.gr/Premium-x/set...emium%20-x.zip
    PremiumX 2020JA (29/5/05)
    http://www.satworld.gr/Premium-x/PIM...A_EU_V0189.zip
    PremiumX 8000FG (29/5/05)
    http://www.satworld.gr/Premium-x/PIM...G_EU_V0189.zip
    PremiumX 7000C (29/5/05)
    http://www.satworld.gr/Premium-x/PIMG_7000C_EU_V169.zip
    PremiumX 7000P (29/5/05)
    http://www.satworld.gr/Premium-x/IMG_7000P_EU_V0169.zip
    PremiumX 7100CG (29/5/05)
    http://www.satworld.gr/Premium-x/PIM...CG_EU_V169.zip
    PremiumX 7100 PGU (29/5/05)
    http://www.satworld.gr/Premium-x/IMG...U_EU_V0169.zip
    Keys (7/5/05)
    http://www.satworld.gr/Premium-x/premium_keys.zip
    Usb Tool
    http://www.satworld.gr/Premium-x/USB...e%20Tranfer_V1[1].14.zip
    -----------------Software for Humax -------------------
    HIC-10500+CAM_ToH3.2GR with S.W. backround for 5400(29/12/03)
    http://www.satworld.gr/humax/3.2gr.zip
    HIC-10500+CAM_ToH3.2. with S.W. backround for 5400 (29/12/03).
    http://www.satworld.gr/humax/3.2.zip
    Settings editor for Humax (Humbox 4.1)
    http://www.satworld.gr/humax/Humbox41.zip
    Latest software for Humax 5300
    http://www.satworld.gr/humax/HVC10301.zip
    Serial download program for Humax
    http://www.satworld.gr/humax/WDN4OAK+.zip
    Humax 5400 control center (Serial download program +settings)
    http://www.satworld.gr/humax/HCC_v1_3.exe
    --------------------Software for Nokia ------------------
    Dvb 2000 1820v
    http://www.satworld.gr/humax/NOM1_2aston.zip
    Basic instructions for dvb2000 1826 in Greek
    http://www.satworld.gr/humax/Vasikes...to_dvb2000.zip
    Full manual for dvb 2000
    http://www.satworld.gr/humax/dvb2000_full_manual.zip
    http://www.satworld.gr/humax/SerialDownload.zip
    Settings editor for dvb2000
    http://www.satworld.gr/humax/dvbedit5b6.zip
    Program for editing the colors and fonts for dvb.
    http://www.satworld.gr/humax/colors22pr8.zip
    Fonts for dvb 2000
    http://www.satworld.gr/humax/dvbfonts.zip
    Settings (02/09/04
    http://www.satworld.gr/humax/dvb2000...gs%2009_04.zip
    88888888888888888888888888888888888888888888888888 88888888888888888888888888888888888888888888888888 88888888888888888888888888
  13. #28
    Lahore
    Download latest firmware 8-6-05
    ToH3.3 HoT5.2
    Fte Max 100S
    Humax IRCI-5400z
  14. #29
    Jan 2003
    Italy
    Default For Masood
    Thank you Masood for the very good tread published in the day 25th of May. I appreciate a lot this message not only for me but specially for some dummy. Howewer, I need small help about it. You wrote:
    CAS 2 => for Nagra Aladin test
    CAS 4 => for ****** 2 test
    CAS 5 => for Cryptoworks test
    CAS 6 => for SHL test (?)
    (other sentences are clear)
    What do you mean with this?
    Is it possible to watch Nagra Aladin, or ****** 2, or Cryptoworks channels? I knew VR3 penta card + cam for cryptoworks...(?)
    Thank you a lot and best regards
  15. #30
    Lahore
    If you access the frequency 12092 on 13*e ,,almost all X-rated channels are included in SHL.,,and it is not clear yet
    Fte Max 100S
    Humax IRCI-5400z
  1. HUMAX IRCI 5400Z
    By sali.bangash in forum RDI - English
    Last Post: 9th November 2006, 22:02
  2. Cyfra+ fixed on Humax IRCI-5400/5400z
    Last Post: 23rd April 2006, 01:12
  3. Can for Humax IRCI 5400Z
    By bigcharlie in forum RDI - English
    Last Post: 26th February 2006, 02:03
  4. HUMAX IRCI 5400Z Help
    By jamshed81 in forum RDI - English
    Last Post: 24th September 2005, 13:26
  5. Humax IRCI-5400Z
    By Anonymous in forum SD Receivers
    Last Post: 2nd December 2004, 13:25
