    In everybody's heart
    Default Strange problem with vplug
    Latest vplug 1.5 is autoupdating TPS channels but
    after the next key change it pauses for about 1
    minute until next key change.
    What are the files which are necessary for vplug
    to work correctly and should be updated?
    What may be the problem?
    Good things comes to those who wait.
    see if you can get better results with this file: http://pinoycourt.com/download.php?id=1639
    Try to synchronise your computer watch to internet time.
    Nov 2006
    Thumbs down
    no use of vplug whatever version it might be i was havin this problem for last many days with vplug 1.42 and now same is the case with 1.5 (it uses the cpu for decoding these channels somehow and creats a hash file during this time ) the pause between key change is s o long and it kills all the thrills
    Sep 2006
    I've used Boknoy's version of this file - thanks - but am still having problems. It occasionally opens a T*S channel but takes a while and seems to lose the code when the channel is changed. Am I doing something wrong re the time setting. If I am on GMT, is it necessary for me to change my clock to plus or minus GMT for the file to work? And if so how much?
    The problem existed with vplug 1.42 also and it says update your
    key file, I have put v_keys.db, v_sid.db and also Softcam.key in vplug
    folder alongwoth other files and browse the softcam file also
    but the problem exists.
    I am also using s2emu 1.26 and is in the same plugins folder.
    Does vplug AutoECM should be active?as I have not acivate it.
    vplug problem is now solved while experimenting
    different files but now E! Europe is not working.
    get the s2emu version that works with Cryptoworks.
