Results 1 to 15 of 16
    Pushtoon Teacher
    Jan 2003
    Bosnia Harzegovenia
    Default HOW TO ENTER BISS KEY =SAMPLE METHOD FOR SOME STBs
    BISS Key's how to enter see this method.
    DVB-S Card: A02123354614
    Next 8000 Series:::A0 21 23 00 35 46 14 00 enter and rebot stb channel work
    Next Plus Series/Supermax 6000CI PLUS:: A0 21 23 00 35 46 14 00
    enter key and exit rebot box channel work fine
    Next 5000/Fortecsatr Platenium 5000V2 one world Hyuandai 1100 data box:::
    Key::A0 21 23 35 46 14 10 04
    (Make new provider in viaccess
    section Provider ID=01 26 00 Enter this key 09 and 08 section)Both NOTE IT.
    Prepared & tested By ZAHIRSB : (c) 2005
    There is no word of IMPOSSIBLE in my dictionary.
    Dreambox 500, Humax 5400Z,Spark DVB 3000 HDD
    One Dish Hotbird,Nail sat, Other Astra 28.2
    Taclobayog City #14 check this out
    hi there Mr ZAHIRSB
    do you know how to enter the BIss Key in Starsat 150D plus... S/W version.. 12.69...coz theres no any BISS to input the key..
    one morething..
    i downloaded the New S/W version 12.70 for 150D plus..with a BISS key Menu...
    but when i enter the valid key.. its not working...
    shows like thiss i ADD a key in BISS.. 1FFA -- ** ** ** ** ** ** **
    pls need advice..
    peace
    Be Smart
    Sep 2003
    Philippines
    Default BISS Key
    Hi,
    Starsat uses Softcam Key so you have to edit the softcam files not from your remote and load it back to your receiver.
    cheers,
    Johnpal
    Default Re: BISS Key
    Quote Originally Posted by johnpal
    Hi,
    cheers,
    Johnpal
    do you have the key editor for this Softcam key....
    i try the Softcam key editor and it says Invalid format.. i notice that this is a bInary file not a Key...
    any idea if you can haelp me..
    peace
    Be Smart
    alibaba
    the easiest way to edit the softcam key is to use a notepad. you can open the file through notepad or you can just click and drag the file to an open notepad window.
    cheers..
    Hi,
    cheers,
    Johnpal
    johnpal .. i try to edit the softcam but theres no BIss to enter the key...
    how you manage to enter the key of BIss ...
    tell me..
    peace
    Be Smart
    SIALKOT/PAKISTAN
    Default Re: HOW TO ENTER BISS KEY =SAMPLE METHOD FOR SOME STBs
    Quote Originally Posted by ZAHIRSB
    any body has full details for all known receivers
    To enter BISS KEY on SkyX 8282 and then u can edit from your remote control, cool and simple.
    Thanks
    Pakistan
    Dear ZahirSb
    if there is nothing impossible in your dictionary then why didnot u fullfil your promise for cracking Zee package, even after the passage of many many months.
    dash
    Quote Originally Posted by da_sh2000
    Dear ZahirSb
    dash
    you think it's as easy as cracking a nut? why don't you try it before you whine about not getting what others promised.
    Pakistan
    dear Beknoy u should not worry abt the others, if zaheer cant do anything then he should not shout for such big claims, if he has something to present then he may be eligible for announcement and praise.
    i m the man of other engineering field, otherwise ur mouth may have not dare to issue the above statement
    Nov 2005
    Doha - Qatar (but Italian)
    Dear ZahirSb
    dash
    Anyway da_sh2000 you are to much aggressive in your 2 posts, for a person asking for help....
    good manners are the base for everything... even more in a forum.
    regards
    DohaSat
    May 2004
    Lahore Pakistan
    Dear Zahirsb i am so happy to see you here in Forum after a long duration
    Thanks to RDI Administration
    Sweden
    Default biss keys
    dear ZAHIRSB
    can you explain more clearly to me if I can enter the biss key to my supermax 6000CI plus receiver without downloading any files like a softcam to my receiver
    Saudi Arabia #53
    humax 5400 can open NBA TV from turksat 1c with the BISS encryption. i can't see the BISS code in the RAM Editor menu option. is there anyway we can see it. just curious.....
  1. how enter biss key in sky 1a ???
    By effibhai in forum RDI - English
    Last Post: 1st May 2006, 03:59
  2. how enter biss key in sky 1a ???
    Last Post: 28th April 2006, 18:50
  3. how enter biss key at sky x reciver???
    Last Post: 17th April 2006, 13:30
  4. How to enter BISS keys?
    By bunty in forum RDI - English
    Last Post: 13th April 2006, 06:25
  5. How method hack biss
    By ridy88 in forum RDI - English
    Last Post: 8th April 2006, 16:30
