Results 1 to 12 of 12
    Jun 2006
    Default PAS 7/10 Signal problem!
    Hi friends
    I am having probs recieving Hor signals from Pas 7/10 satellite, while the Ver signals r stronger. But my neighbours r sharing from the same dish as i am but they getting both V & H signals. Wats wrong?
    My STB is StarSat 3300CU
    regards
    Africa-Kenya-Nbi
    Quote Originally Posted by satpal123 View Post
    Hi friends
    regards
    its also good to know whether you are on dual lnb,
    ku or c band,
    running two parallel cables or just split cable,
    using a diseq or not.
    your set up will help know where your problem could be coming from
    Dstv HD PVR
    Jun 2006
    Smile hey
    Single LNB & its C-band....its been split wid a splitter
    One wire goin 2 my neighbours Diseq & the other 2 mine Disceq
    Thats all
    Africa-Kenya-Nbi
    Thats all
    its not easy though possible for two receivers to swith c band lnb to both horizontal and vertical polarities at the same time. so your problem could be your neigbor is on vertical and you cant go to horizontal in that case.
    more views will come fro members
    Dstv HD PVR
    Jun 2006
    Well i dont think so coz i went & checked it on their reciever, they getting channels from both H & V signals, while i turned my reciever 2 the V signal channel but it didnt affect them.
    21.95° N 97.06° E
    Sir cogil is right.U can't split C-band lnb with power passing splitters bcoz. it can give u one polarity while receiving two receivers.U need dual output C LNB for two receivers.
    Thanks.
    " 李俊明 Born To Help People "
    Jun 2006
    Thanks.
    Ok will remove my neighbours connection & check wid a single connection...lets c if it works then.
    Zimbabwe
    Thanks.
    I bag to differ if you put a diseq switch inbetween you can split the only down side is you have to be watch channels on the same polarity
    nothing at the moment
    Africa-Kenya-Nbi
    yes you start with that, if you still get no H polarities, then the next will be your receiver settings for V and H
    @ mafutah,
    the language could be wrong but am sure mr yan still means splittin the polarities with a power pass splitter, like you say they both have to do V or H on both receivers at the same time
    Dstv HD PVR
    Jun 2006
    But from last month only i am not able 2 recieve ne H signals from that Sat.
    Donno wats gone wrong?
    21.95° N 97.06° E
    @mafutah,
    sorry for my english.I mean if u want both polarity u can't do with these splitters bcoz. they can give only one polarity at the same time(with two receivers).
    @Sir Cogil,
    Thanks bro.
    Jun 2006
    RAWALPINDI,PUNJAB,PAKISTAN
    dear brother
    you have to change ur lnb with SINGLE CABLE SOLUTION lnb which have not any 13/18 volt switch you have to do some changing in ur lnb settings which is lnb lo frequency is 5150 and other is 5750 and for horizontal channels u have to minus 600 from frequency suppose if \
    b4u movies frequency is 4064 then u have to put 3464 to receive it then both can receive without any problem.thnx
    that lnb is expensive from normal lnb here in pakistan its cost is 1250 rupees and normal is for 400 rupees THNX
