    Ali4u
    Default RSA keys ...Help me !
    hi ..
    can somebody give me a breif description of RSA keys ! which emulator needs RSA keys ....which cannels can I open with RSA keys from hotbird ...and where can i get this keylist ... if any available ...i m sorry ..if i said something wrong ... as i really dont know about RSA keys ...today I tried to open cartoon channels with the new s2emu .. which i used to open with emunation 1.1a ....so i found the message in s2emu info ... that RSA keys list not found ....so plz help me in this regard ... thanks all for co-operation in advance....!
    NOte : i am using skystar2.
    just use s2emu 1.14 and put the latest softcam.key on your directory and it should clear the channel.
    Ali4u
    Default thats not the solution..
    thats not the solution .... and lemme tell you ..that i m already using the latest s2emu and updated softcam.key from ******** / match1 files. ....
    what i wanted to know ... is different ... i think u ddnt get my point ...what i have asked for .... ? any how thnaks ...
    ok then, i will answer your question.
    most of the channels being beamed nowadays are beamed using the RSA encryption method, TPS and others are somewhat using the more advanced AES encryption method. RSA stands for the name of the inventors of this encryption technology.
    A method of public key encryption developed by Rivest, Shamir, and Adelman at the Massachusetts Institute of Technology which is sold by RSA Data Security Inc. RSA technology is one of the most popular public key encryption technologies currently available.
    in satellite parlance, RSA also refers to the management keys, you get hold of these management keys and you will be able to extract the necessary codes to pair it off with the RSA and thus able to generate the pictures and sounds on your TV.
    if your s2emu complains that it cannot find the RSA keys, it means that you did not update your Cyfra+ keys to that for the month of May.
    Iraq
    Default RSA?
    it is much clearer now..
    i like u guys i hope more will come out and share their knowledge about satellite technology..
    FYI
  1. <<{ SEX View latest keys }>> biss keys
    By fida_689 in forum RDI - English
    Last Post: 13th May 2007, 14:56
  2. KEYS: to keys section
    By cogil in forum RDI - English
    Last Post: 7th October 2006, 22:40
  3. var/keys/c2gbox.cfg si var/keys/nds
    By mugdg in forum DREAMBOX
    Last Post: 26th August 2006, 00:10
  4. Keys, numai Keys
    By Gregg23 in forum RDI - Satelit
    Last Post: 23rd February 2006, 01:23
