Results 1 to 6 of 6
    Africa-Kenya-Nbi
    Default TELSTAR 12 - need set up help
    Beatsat wrote
    Help with setting up Telstar12 15W
    Hi
    Iam in Zvish.., Zim and have been failing to pick up this satellite Telstar 12. i have tried several times but all in vain. I have a 90cm dish and wiz 222, Wiz 260 & DSD990 (Dstv).
    I dont get any signal so I was thinking that maybe my dish size is letting me down. What is the Az and El that I can use so that I might get a rough idea. which transponder has the highest signal which i can target DMX, Earth, BYU etc.
    And lastly which channels are veiwable on this satelite?
    Thanks
    anyone receiving telstar 12 in zim, do help out
    Dstv HD PVR
    Jul 2006
    Timisoara, RO
    The strongest signal which I receive is on 12573V SR 6111
    However, hereis a test card ans also the SR is low so maybe try 11224H SR 18368 (DMC). Very good signal also here.
    W 0D0404 00 0000000000000000759734DD42CFC824 ; DMC
    good luck !
    Zimbabwe
    Thank you for the info, will try.
    Cogil, thanx also for posting my request in this thread, I just thought that I might be the only one with the problem so that why I sent in a PM.
    oOo BeatSat oOo
    Zimbabwe
    Hey My man B you should send me an pm with your number.
    Here goes
    First problem your 80cm dish is not quit sufficient. Don't get me wrong it works but to much lab our and fewer channel well only the English one will pop up but you see transponders and feed come in so you want to always get what you can. I recommend 180cm dish.
    Telstar 12 is virtually in the opposite direction of your pas 7/10 (*IS 7/10) [d.s.t.v,s.a.b.c dish] don't forget you lnd be setting considering you are in Zim you probably bought a universal lnd select universal on your Wiz-222
    lo - 9750 & 10600 I know it usaly write 10700 change it to 10600
    here are some pics for the out side setting... okay i first have to upload nono how about you go here
    h**p://www.satlex.de/en/azel_calc-params-pr.html?satlo=-15.0&user_satlo=&user_satlo_dir=E&location=&la=-20.3305&lo=30.0473&country_code=zw&diam_w=75&diam_ h=80
    I have already put your location detail in the link above.
    don't forget to locate the playboy channel.
    nothing at the moment
    Jan 2007
    Thumbs down sir
    please tell me wiz 222 software link
    Zimbabwe
    this is the thing I can give link but how will you load it.
    send me a pm and I might for get about the thumbs down and hugh font.
    just kicks use cnx uptools and search the forum like is some where here of be nice to cogil he usually remember all post
    as for the cnx tool please use version 6.1.0*** is the one with provision for adding satellite. I can't send it to you now coz somebody cursed me and my laptop is dead and I dont remember which server i posted the backup
    Yeapeee this is my 100th post
    come on lets party
    Last edited by mafutah; 25th January 2007 at 22:26. Reason: Notice it was post number hundred
