    al
    Default hello
    I dont know why spice platinium on hotbird is not aviable to watch on my stb.
    I got a samsung 9500 a ci with martix revolution . I can see tps and multi ,soo the keys are ok.
    I cant understand why i cant see spice platinium?
    punjab- pakistan
    Default hi dear
    load defalut key your stb and enjoy it will work if not then mail me i will send u its coad i have not at this time
    al
    is problem of my stb or my matrix ?
    @matri,
    there is new update for matrix dated 10/5/05. load that and you will have spice in your life.
    phi
    why i cant upgrade my sky1 receiver and srt3680? i used rs 232 cross connection but failed, i also used straight, but failed. can u help me? do we have software for these receivers to have key editor?
    Thanks
    Default cartoon network & Humax 5400
    why cartoon network(cyfra) is not working in my Humax 5400 ToH6.5C even if I enter the code for February 2006.
    asia
    Quote Originally Posted by ruzm
    Thanks
    here are the possibilities
    - check if you have the right loader
    -check if you have a cable continuity by doing so used a tester and check each both end if there is a a cable resistance
    -use comport 1 if not working com port 2
    -make sure your all your comport are working
    -dont power up your stb first. run your loader then put the soft and pwer on your stb
    wish this will help you
    Bu Ru Hu Xue, Yan De Hu Ze
    Ton Zhou Gon Ji
  1. Possible problems on Eurasiasat 1 at 42E
    By first_zipper in forum News
    Last Post: 5th November 2006, 06:33
  2. problems problems problems
    By fone in forum SD Receivers
    Last Post: 26th September 2005, 09:18
  3. hi for ur all problems
    By abdulsaboor in forum RDI - English
    Last Post: 4th August 2005, 16:08
  4. ID problems...
    By wahizul in forum RDI - English
    Last Post: 21st May 2005, 13:18
  5. DVB Dream Problems
    By MrMxyzptlk in forum Placi DVB
    Last Post: 16th November 2004, 16:30
