    al
    Default hi , I nead some help plz
    I have a stb samsung 9500 a ci,
    yesterday I bought a Matrix reload, she is upgrated with new files soo is okay, but,
    I see that not all keys are new . I want to put some new keys but I dont know how ?
    1.using my samy inside menu, .. ecc puting keys with my remote control!?
    2.or using a programer for cams ?!
    RESPECT
    THX
    updating your MR can be done several ways. the most popular and most cost-friendly is to it via pcmcia port on a laptop and use ucas1.3 for updating the mr files. another is to use funcards to update the MR, then next is to purchase a cas2 interface from duolabs.com and use that to reprogram your MR. (further info can be found for updating the cams from http://www.matrixcam.com/matrixreloaded.htm
    You can edit the keys on the MR manually though if you wish to, it's using the DEC format so you have to enter it accordingly. most of the updated keys posted under the keys section has a corresponding MR keys value. good luck.
    al
    THANX boknoy_ph
    Australia
    boknoy
    Will similar method work for X-cam ?
    al
    by the way
    I dont know why spice platinium on hotbird is not available to open on my stb.
    I got a samsung 9500 a ci with martix revolution . I can watch tps and multi ,soo the keys are ok.
    I cant understand why i cant see spice platinium,if this is channal inside this boquet of tsp,
    is my samy that is not okay or the cam dont suport it ?
    @woz,
    there has been a program for xcam which will enable it to be reprogrammed using the serial connection from your laptop and with a dummy card of some sort, like tripe programmers (i think xcams are being upgraded with loader cards like dragon). so please take a reading at http://www.la-cafetera.com/xcam.htm or www.toecuttersden.com
    After updating with the patch as mentioned above, you can use your laptop pcmcia to update the cam.
    Australia
    boknoy_ph
    Thanks for the links, I will look now.
