Results 1 to 2 of 2
    AndroZ
    Default No signal after firmware upgrade
    Please help! , have had this problem for a while now. i have a 5400z and everytime i try to upgrade firmware, i cant recieve signal and the receiver freezes when i try to scan for channels.
    i have only one LNB, have tried cleaning the firmware and channels using Josje01_Cleaner, then installing pmc tables as well as hnf file, but havent been successful.
    should i try the AllFlash_Reset_v12.hdf file and if so where can i find it
    Educator Teacher
    Apr 2006
    Nowhere land
    Default NOT A SOLUTION BUT AN ADVICE
    first of all a presume that there was a signal before the firmware update(upgrate). so first u should do the same that u did before upgrating your rcvr, boot cleaning, then uploading the firmware, the patc and that the key table. if the bin (the key file) file is not compitabile it could be the reason for freezing the rcvr. so do the uploading of the old firmware scan and then upload the key table...if u dont know how to do that search for a manual in the program folder or wait for some1 to give u some tips...i hope this will help a little...
    Knowledge is power
  1. Which loader is used to upgrade signal reciever
    Last Post: 5th October 2006, 23:23
  2. Is there any way to upgrade my SIGNAL- SR555 receiver
    By valiyana in forum RDI - English
    Last Post: 17th June 2006, 22:27
  3. Upgrade Firmware - Strong 4125 Evolution
    By AlaMicSiNegru in forum SD Receivers
    Last Post: 2nd June 2006, 16:03
  4. Cineva cu experienta in upgrade de firmware un ajutor
    By soporan_emil in forum SD Receivers
    Last Post: 11th October 2005, 12:09
  5. Channel Editor and Firmware Upgrade.....enjoy
    By lovebird in forum RDI - English
    Last Post: 11th May 2005, 11:17
