Results 1 to 12 of 12
Thread: help kaspersky
    24.64° N 46.77° E
    Default help kaspersky
    hi,
    having instaled kaspersky v6.0 antivirus but kasperskay blocked updates asking to contact dealer. anybody help me in this regard.
    Dec 2006
    Default Because the key is blacklisted.
    Hello,
    I had that problem a couple of days ago. It happens because the key has been blacklisted by kaspersky.
    There are some new ones floating around that are still "virgin" and work.
    try this link for more info http://www.torrentspy.com/torrent/91..._411_Final_zip
    philippines
    post your email address, i will send you not blacklisted keys..
    24.64° N 46.77° E
    pls email me: [email protected]
    HONG KONG
    hello dear friend i am thank to your my email is here: [email protected]
    n00b Teacher
    pakistan
    try DZ3A3-7XGVU-DH1YX-NXJYP
    philippines
    to manc & danny786,
    I sent to your email the registry entries. Just choose which one will work to your program...
    HONG KONG
    Quote Originally Posted by carlomaderazo
    to manc & danny786,
    thank you dear but the key not working (kis6.0.1.411en)
    philippines
    Quote Originally Posted by danny786
    to manc & danny786,
    Try the key one by one as i did also...
    24.64° N 46.77° E
    to manc & danny786,
    many thanks carlomaderazo.
    Nov 2006
    Reinsatll Antivirus and Apply any reg key, Do not update antivirus from Karspsky update, from the software. Download the update from the karspsky web site in the form of zip file, Just update from your karspsky from the source of zip file.
    Inimos din cale afara Expert
    in my own mind
    Why don't you try this...
    1- go To ( Start ) then ( Run )
    2- Type ( regedit ) and press ( OK )
    3- Go To ( HKEY_LOCAL_MACHINE\SOFTWARE\KasperskyLab\AVP6\Data ) & Right Click On ( Data ) & Choose ( Permissions )
    4- Choose ( Advanced ) From The ( Permissions For Data ) New Window Opened
    5- In ( Advanced Security Settings for Data ) Window .. There is a sentnce which begin with ( Inherit from parent ... ) click on the nike or check mark to remove it
    6- After Removing the check or nike mark you will get a new message .. choose from it ( Remove )
    7- Then in ( Advanced Security Settings for Data ) click on ( Apply )
    8- After Clicking Apply you will get a new message choose ( Yes )
    9- After That Press ( OK ) In ( Advanced Security Settings for Data )
    10- After That .. Press ( OK ) In ( Permissions For Data )
    11- After That Make An ( Exit ) For ( KasperSky ) .. & Run It Again
    12- You Will Notice That The Kaspersky Icon Is Not ( RED ) But Its ( GRAY ) Which means that the program is not activated
    13- But if you opened it you will see al things are working perfect 100% Working
    What Happened To The Program After These Steps ?
    - You Will update the kaspersky database manually ... no automatic updates
    - thw windows security center will tell you that the firewall or\and antivirus is not working ... bec you made the kasper seemed unactiviated
    at me seems to work and remember update manually...
