Results 1 to 11 of 11
    Hindustan
    Default Skygrabber - System Halt :(
    Hi friends
    I have just configured my setup with Skystar2+progDVB+SkyGrabber with NSS6. I'm getting massive data available for grabbing from NSS6.
    But the problem is the System getting hanged/freeze after few minutes of run and after that all gone... No keyboard no mouse ... After that I'm forced to hot boot the system
    Any help from members ?
    Technology Makes You Live
    Default Re: Skygrabber - System Halt :(
    Quote Originally Posted by urpradhan
    Hi friends
    does this happen when you are viewing encrypted channels? maybe your power supply is not enough to run all your peripherals as pc dvb-s cards require quite a lot of juice from the cpu and the electrical power supply (stable PSU, high wattage).
    Hindustan
    Hi friends
    Hi
    No, its not encrypted and not a channel.
    Its a DATA stream on NSS6 for Internet.
    I'm able to grab data for few moments and perfectly grabbing data from the satellite. But after few minutes the system freezes NOTE:All my equipmets are connected to my APS UPS.
    Apr 2006
    Pakistan, Multan
    This problem also happen with me and it start from when I start latest crack version of Skygrabber. It is not only from Nss6, with other sats too, Like Eutlsat on 7 E and from LM1.
    Dream Box 800HD, Neotion 3000, SS2,
    12 Feet Motorized Dish 128 E to 3 E
    yes, i know it is a DATA steam, that is why i asked if this happens also whenever you are viewing encrypted channels.
    anyway, as suggested above, the problem might be your skygrabber.
    Hindustan
    Default Hi
    Hi
    Though I ve invested Rs 7000/- INR on my setup with my PC, I'm not able to watch any encrypted channel from NSS6 Even though the FTA channels which are broadcast by DishTV India, I'm not able to watch them But earlier I heard that if I'll punch the channel information/data to STB/PCI card I should be able to watch them. Any solution to this ? Lets say ETV Gujrat is FTA, but DishTV pkg encrypts it and I'm not able to watch that channel.
    Hope to get a solution to this from members.
    Hi there
    exactly the same problem here, grabbing from OPenSky (Eutelsat W 7E) for some time then freeze, then reboot, then reboot again because of saccades in mouse movement, then ok.
    skygrabber version is 2.75, it should be the faulty one here. 2.76 is out but no cracks available around, still searching so no grabbing until new craks came out.
    if you want you can switch to Datasky, i used it on Alice SAT (Astra 19.2E) some time ago, very good and stable (version 0.09 excellent BTW)
    Hindustan
    Quote Originally Posted by wij the king
    Hi there
    Gr8..
    Thank you for the reply.
    Ya, Skygrabbaer 2.7.6 is out Y'Day. Lets wait for the cracked version
    And I'll also ve a try to DataSky ...
    Hi there
    Gr8..
    Hi again urprahdan
    it's just to tell you that i found what the problrm was, in fact the cracked version pripority is set up by default to... REAL TIME
    so when accessing disk to write or delete big files, system hangs
    so basically go to task manager and under "processes" tab, right click on skygrabber task --> Set priority-->normal.
    i did that 5 days ago and till now, i grabbed from Eutelsat W3 for at least 4 hours without nay problem.
    hope it helps, bye.
    Nov 2006
    Default SktGrabber
    What is the biggest file you have been grab, What is the speed you are getting.
    Hindustan
    Default hi
    Hi
    I ve tried that option to set the priority of Skygrabber in TaskManager earlier, without knowing the reason as I sw it was eating too much CPU cycles. So set that to below normal ! Atleast its not hanging now, but not completing/finishing any single file download After few time the timeout is occurring and not completing the file download.
    So now I'm happy with FileGrabber module with progDVB. It works fine but you can not set the file limit for individual file extension
  1. digiturk's system might have been changed to another system
    By xcharlestonw in forum RDI - English
    Last Post: 18th June 2006, 00:13
  2. SkyGrabber 2.3
    By charetika in forum RDI - English
    Last Post: 17th April 2006, 07:37
  3. SkyGrabber 2.3
    By fansat_03 in forum Placi DVB
    Last Post: 4th April 2006, 17:30
  4. SkyGrabber 2.2
    Last Post: 1st April 2006, 23:57
  5. SkyGrabber 2.0
    Last Post: 13th March 2006, 09:27
