    Nov 2006
    Default plz help my humax 5400 signal level is always maximum !!!!!
    the problem happened suddenley
    -signal level is always maximum (100%) and no channel is recieved
    - signal level still maximum even when the lnb is not connected
    -when starting the box the loader version h1.37 apper on the screen then message (ra) appear on the box screen then reciever works, i can switch normally between channels and the humax picture on tv i s normally, but bad signal appear on tv screen and signal level still always maximum and signal quality always zero
    -i tried another two reciver on same lnb works normally,i tried to install latest patches and then tried the official firmware(H1.37 /0016.0400) same problem still exist,any help please,any problem on hardware?
    21.95° N 97.06° E
    Hi friend, ur tuner may be dead and another possible is resistors around ur tuner is something wrong. ( i can wrong )
    Regards.
    " 李俊明 Born To Help People "
    Try to get another channel list.
    Indonesia
    Do you still receive channels with the receiver? if no, your tuner is gone, if yes, the MF from your tuner is sending to much signal, in both cases you should replace the tuner or live with the fact that your signal is not showing correct.
    succes
    Terrorist use the muslim faith for there privat intrests, and should be killed more painfull than their victems
  1. AltDVB level signal
    By kenntos in forum Placi DVB
    Last Post: 11th June 2006, 19:14
  2. Humax 5400 No signal
    By pmmali in forum RDI - English
    Last Post: 7th May 2006, 21:21
  3. SS2 REV 2.3C Signal strenght & quality level
    By FLORIN_MX in forum Placi DVB
    Last Post: 6th January 2006, 14:29
  4. Signal-Problem with HUMAX 5400
    By Hawk in forum RDI - English
    Last Post: 31st December 2005, 03:48
