Results 1 to 12 of 12
    Jul 2006
    Default rs232 to USB Help
    Hello
    Need drivers for rs232 to USB
    And process to install as mine does not work
    Thanks in advance
    Oct 2002
    Belgium
    Default Driver
    everie usb adapter has or come with a cd or you have to know from wich manufacturer it is so you can find it on the manufacturer website
    Jul 2006
    Yeah,
    It came with a CD from Huge pine, & made in China, so far no luck with web support.
    Oct 2002
    Belgium
    Default usb adapter
    you have to see wich comport is free maybe there is also a problem sometime or you have to buy a better product that works than fine
    az30094
    Default Re: rs232 to USB Help
    Quote Originally Posted by dom06
    Hello
    Thanks in advance
    Hi dom!
    Did you mean RS232 to USB? Are you sure? I have not come across such a thing. It must be USB to RS232. Please check.
    what happens when you install from CD? most usb-rs232 converters will install it on com port 4 or higher, so make sure which comport you are using by going to control panel/system/hardware/device manager/comports/properties/advanced and change according to your needs.
    Default hi
    Hi dom06 .... check this link http://www.alsat.co.uk/forum/showthread.php?t=46948 it might help
    Jul 2006
    Yeah Boknoy,
    I did in fact configure the port & tried all the 4 ports available on the loader, it says connection OK with STB on one port but does not download bin file (sky1a STB)
    Appreciate all ur help
    Byte Stalker Mentor
    Planet Earth in Universe
    this is really and ongoing problem, very few usb to rs232 converter works. its a timing issue, remember the speed difference on the two, & if the implementer scrimps on crutial parts it may or may not works on a specific laptops!
    Jul 2006
    I use a null modem cable from my stb, which in turn is connected to the rs232 & then to the usb of my lap top, as the rs232 to usb has a male pin on the stb connection side, could this be the problem. Other people have also done this from posts on other forums.
    As per Pookiyakal's link
    Thanks Pookiyakal
    Pl advise
    Byte Stalker Mentor
    its does not matter whether the rs232 has male or female connector, the pin configuration does not change, just use a gender changer to suits one's need!
    Default is it ok now?
    Thanks Pookiyakal
    Pl advise
    Welcome m8 .... hope ur problem has been solved by now
  1. RS232 en portatiles
    By sinnoflooder in forum RDI - Espańol
    Last Post: 30th October 2006, 12:34
  2. Adaptor PCMCIA-RS232
    By hack2006 in forum RDI - Satelit
    Last Post: 9th July 2006, 01:03
  3. USB la Serial(RS232)
    By emil67arro in forum RDI - Satelit
    Last Post: 2nd April 2006, 10:11
  4. New Guys (RS232 Connection)
    By sahi in forum RDI - English
    Last Post: 21st September 2005, 18:45
  5. help for rs232 cable
    By jameel in forum RDI - English
    Last Post: 2nd July 2005, 08:05
