Results 1 to 6 of 6
    Pakistan
    Default What is the SOLUTION - Help Wanted Help.......
    Friends!
    Help Me OUT
    There comes a sound like "Katich" from my CPU.My system halts.I have to restart it. it some times showes no disply on my moniter so I have to shut down it and ON it again.
    Due to this I loose all my unsaved documents and data ,I have to conect internet again and again.Please why it is so.Please tell me its solution.Thank
    Wattoo
    Africa-Kenya-Nbi
    either you are soon loosing your hard disk
    or you have more than your computer can easily handle loaded in.
    maybe it will soon crash, so start early and save your docs before then.
    or back up before, and change your Hd or whole comp - you need a bigger one
    Dstv HD PVR
    ticking sounds? could be a HDD problem as cogil stated. but a HDD problem does not shut off a monitor. please explain what is a Katich sound? i suspect a faulty cpu fan, thus resulting in overheating. check all your fans if they are working and make sure that all vents are open.
    az30094
    I strongly suspect your Power Supply. A capacitor may be going southwards. Get it checked immediately before any other major (I mean costly) component fails.
    Africa-Kenya-Nbi
    hi mathila, i thought youd recollect better if you carried on with this thread: still "katech"
    mathila wrote:
    Friends!A few days ago I tried to install PC suit for Sony erricson from their provided CD with mobile set.
    The installation process stopped incomplete.My computer does not start normally.I opened it in safe mode.
    It showed the message"The recent software or hard ware change may caused this,system is not started Normally."
    So I performed the system restore in back date. Then it booted normally.But after a few minutes
    a "Katech" sound came from my CPU. It haulted. I waited afew minutes .I restarted it. But after afew minutes it again haulted.
    SO I installed the fresh copy of Win XP 2006 .
    But the problem is still present.
    I have to restart it. It some times showes no disply on my moniter after restarting.
    So I have to shut down it and ON it again.
    Due to this I lose all my unsaved documents and data ,I have to conect internet again and again.Please why it is so.
    Please tell me its solution.Thanks.
    Help Wanted urgently
    _________________
    Wattoo
    May 2004
    Kuwait
    @Mathila
    it might b a power supply problem,just make a back up of ur files before it craches.
    shutsown all the electricity completly, take out al the switches from electricity switch boards then put them back properly again, switch on the electricity, swith on ur PC and once reboot it.
    it may save u for some days for crashing...
  1. Angel Box Solution !!
    By SatThaiTV in forum RDI - English
    Last Post: 28th June 2006, 12:03
  2. Nobody have solution for Fullx1-2
    By shadowkhan in forum RDI - English
    Last Post: 24th September 2005, 18:03
