Results 1 to 3 of 3
    Apr 2006
    Default AltDvb Audio Problem
    I am using anexus-s with a ATI X1600 and when I use AltDVB in the soft mode
    I either get a freezing picture with good sound or a good picture with an
    echo. Before I fried my hard drive I had it working good, but since then
    no luck finding the right combination of files yet. The picture on the T/V
    is a split second ahead of the pc monitor and I get the sound twice on the
    pc, one that matches the picture on the T/V and one that matches the
    picture on the pc so I end up with an echo. I am wondering where I can
    find a working "Configeration","Filter",and "Graph" folders from a working
    AltDvb with a set up some thing like mine or tell me where I screwed up
    the settings. Thanking any one in advance for help.
    search for graphedit, if you don't have it already, and use that to mix and match the codecs which best suits your needs. i suggest you use nvidia (yes, even on ATI cards). google for Roger Rabbit codec pack and use that for your filtergraph options.
    for the life of me, i cannot understand why you opt software mode instead of the hardware mode? hardware mode does not need any kind of filtergraph, etc.
    Apr 2006
    I have an older 27" t/v but on my PC I have a 6 speaker sound system and a 19" lcd monitor. Thanks for the info, I will play with graph edit.
  1. Startrack 709-CI audio problem
    By Kahlid in forum RDI - English
    Last Post: 15th January 2006, 04:41
  2. Hum TV on Pas7/10 audio problem?
    Last Post: 11th January 2006, 13:43
  3. DM Digital Audio problem
    By Afzalnajaf in forum RDI - English
    Last Post: 3rd January 2006, 19:00
  4. THAICOM 2/3 FRO.3585V26667 AUDIO PROBLEM HELP ME
    By LUQMAN_ALI in forum RDI - English
    Last Post: 4th December 2005, 06:59
  5. Dm audio problem on viva
    By malikshahidjeee in forum RDI - English
    Last Post: 10th November 2005, 05:39
