    dead sea
    Default skystar 2 problem
    hi
    i need some information about skystar 3 or anyother card which can work same or better than skystar 2 . i dont know what is the problem but this card is doin somethin wrong in my system . simply when this card is installed i get disturbed audio in all my movie and song clips which r already on my hard drive but when i remove SS2 it comes to normal dont know what is the problem .
    So plz let me know if there is new version of SS2 i am using the latest driver version 4.4.0
    thnaks
    Und Tschüss!
    Feb 2006
    which viewer are you using?
    try progdvb,most use this and can give problems especially newer versions of software.
    try altdvb and dvbdream as alternatives,if this dosn,t solve your problem try a deletion of your files from control panel and then a new installation.
    change PCI card slot on your PC as the IRQ must be shared or in conflict. get nexus-s or skystar1 if you want premium performance.
    dead sea
    thanks boknoy_ph i was actually waiting for your reply yes it was very strange but i found the reason y this was happening actually my dish was out of order and signal was zero during these three days i was able to find out what the problem was . i tuned my dish put the card in the same slot and everything was fine .
    now all my songs all dvd clips and everything that is using audio is allright
    tell me about nexus is this thing will work with prog dvb and all the pluginns
    many thanks
    Und Tschüss!
    of course, nexus-s will do all of your pc dvb-s needs, and more. it consumes less cpu cycle from your pc because it has onboard mpeg decoder. it can even run nicely on a p3-500, as the specs suggest, whereas other pc dvb-s with software mpeg decoding like skystar2, twinhan, etc, requires a good amount of cpu power and very nice matching of codecs to your existing hardware on the pc for optimised performance.
  1. Vand Technisat Skystar 2 , Skystar 1
    By albatran in forum Shop
    Last Post: 30th September 2006, 17:05
  2. skystar 2
    By peetov in forum RDI - English
    Last Post: 12th August 2006, 22:10
  3. Skystar-2 Problem while changing the polarity
    By iqbalbhawana in forum RDI - English
    Last Post: 7th June 2006, 21:23
  4. skystar 1
    By ianyika in forum Shop
    Last Post: 16th November 2005, 10:14
  5. Replies: 9
    Last Post: 15th November 2005, 20:51
