Thread: Lnb noise level
    Jun 2006
    Default Lnb noise level
    Is it worth investing to upgrade my lnb which has a noise level of 0.3 dB to a new one which will have a noise level of 0.2 dB.
    Can anyone suggest a good brand for a 0.2 db lnb (available in dubai and name of dealer please).
    My dish is pointing to nss6 from inside my balcony and sometimes I am not able to receive the dishtv transponders here in dubai.
    Africa-Kenya-Nbi
    maybe its worth it, though i do think its not prime, i just think you move your dish out of the balcony and you'll have better signal levels.
    remember in the balcony and out of the balcony are two different positions
    Dstv HD PVR
    Jul 2006
    Bigger dish will help, 210cm dia works in Khobar Saudi, think you need 150 cms dia. Or try Santech Ku band lnb they are good to recieve NSS6 & is available in Dubai
    Jun 2006
    RAWALPINDI,PUNJAB,PAKISTAN
    dear friend
    check that is that night time when u dont get nss6 singnals i have some problem also with my system and at night time i dont get vertical signals from nss6 but horizontal are ok at all the time and dish tv is on vertical plz check that is ur power and quality both signal goes to zero percent or any other problem.plz tell me.
  1. AltDVB level signal
    By kenntos in forum Placi DVB
    Last Post: 11th June 2006, 19:14
  2. looking for best low noise c-band lnbf
    By dugizul in forum RDI - English
    Last Post: 14th March 2006, 13:41
  3. CHECK OF LNB NOISE FIGURE
    By karmyog28 in forum RDI - English
    Last Post: 12th February 2006, 07:40
  4. where I can buy Ku LNB with 0.1dB noise
    By zolaforever in forum RDI - English
    Last Post: 17th January 2006, 04:01
