    Default need help on USB to RS-232 cable...
    Hi all...
    I need help on updating my receiver using USB to RS232 cable... i want to update my starsat550D using the USB to RS232 cable from my laptop... i connected the cable in usb port and another (2-3 3-2 5-5) cable at the end of the com port and connected to my receiver.. i had loaded the SW for the USB device before .. when i try to upload using com1, it shows waiting for B00B ... but no activity after that... can someone tell me did i miss any step in b/w .. or this way of updating the receiver will not work Pls Reply... Thanks in advance
    Behind Thor
    If you used the same cable before it must be the software is not compatable with your model as there are a lot of different models Starsat.
    check your port assignment at control panel/system/device manager/ports to coincide with your loader.
    Educator Teacher
    Apr 2006
    Nowhere land
    Default read this
    u probibly tryed to upload some .bin file that is not compatibile with ur reciever try finde some file that is compatibille even is old and try uploading if is ok that u had no error in u reciever software but ur .bin file is non compatibile...
    Knowledge is power
    Jul 2005
    dubai
    instead of using usb , try com port(9 pin) if your laptop having one.
    similerly try different com port(com1,2...)
    rs232 cable should be null modem
    open the loader
    given start
    waiting boob will appear
    given ok
    then the uploading will start or some error messagewill come
    if all this will not work try from a desktop pc 9 pin com port. it will work
    hai every body
    he wont be using a usb-serial adaptor if his lappy already has a com port.
    the problem with these adaptors, they are finicky when it comes to drivers.
    Default port configuration
    when i plug in the USB cable , the system automatically detects it ...While using simple loader (which comes with each versions of starsat updates ) it shows -- "waiting for BooB" only on com1 , if i select any other com port in simple loader, it shows com error..i tried with straight cable and cross cable ( from the com port of the USB -RS 232 cable ) , but of no use. I tried using different drivers for the USB - RS232 cable ... do i have to check anything else
    Tom-----> as boknoy mentioned, I dont have a com port on my laptop
    xNowell ------> i'm sure the bin file is ok...i had uploaded the same bin file from my desktop computer to the receiver
    Fred ----> software is also ok ... it was working fine from my pc
    ok, which chipset it is using. could be drivers issue. if it is somehow working on com1, then configure it as such. but go back to control panel/system/hardware/device manager/comports properties/advanced and lower down the buffer settings. the buffer setting usually corrects most connection errors.
    if that does not solve the problem, try to find out the chipset it is using or at least the manufacturer, maybe you need updated drivers.
  1. CABLE-138/5 NULL MODEM CABLE 9F/9F 5M
    By romeoX in forum RDI - Satelit
    Last Post: 14th January 2006, 08:42
  2. I-Cable
    By da_sh2000 in forum RDI - English
    Last Post: 4th January 2006, 08:18
  3. why zee gone from cable tv
    By geosaleem in forum RDI - English
    Last Post: 27th September 2005, 11:01
  4. NOU:Uni Cable Lnb
    By nirolf in forum RDI - Satelit
    Last Post: 27th June 2005, 11:31
  5. HK Cable on 138
    By ssunny in forum RDI - English
    Last Post: 3rd June 2005, 17:54
