Results 1 to 2 of 2
    in canal,langa aurolaci
    Default pt.cei ce si-au bulit biosul la player cu firmware gresit
    Rescrieri/Refaceri/Update BIOS (PC,Laptop,video,interfete SCSI,etc), orice tip. - Programari memorii Prom,Eprom ( stergere UV),NVRAM (inclusiv zona PhantomClock),EEprom (inclusiv spatiul XData),Flash,RTC(cu NVRam), FirmWare_Hub (FWH: Intel,AMD,Atmel,SST,ST,Winbond,...) in capsule format DIP/PLCC/SOP/TSOP/SOIC: 26xxxx,27xxxx,28xxxx,29xxxx,37xxxx, 39xxxx,40xxxx,49xxxx,50xxxx,57xxxx,ds12xx - Programari/decodari circuite GAL/PAL/PALCE/TIBPAL/ATF. - Programari circuite MicroWire (93c06/46/56/66/76/86/96). - Programari circuite I2C (24c01/02/04/08/16/32/..., 85c72/82/92/...). - Programari circuite MaskROM 4/8/16bit (74s188/74s288, 27s18/27s19, uPB400/uPB410/,...). - Recuperari de date din Agende (Organizer-e) electronice defecte. - Programari circuite/memorii TV - Rescrieri memorii Flash de telefon mobil. - Rescrieri memorii Flash/BIOS camere video/foto. Servicii inclusiv pentru placile cu memoria/circuitul lipit. 0722.274.114, [email protected]
    745.59.82
    vreau sa ajut un adevarat domn care s-a purtat ft.frumos cu clientul adica cu mine si i-am pus ooferta precum si nr.de tel.aici sa aiba parte de cat mai multi clienti;
    GABI - 0722274114 - din partea lui Marcel (omuldenisip)
    backup_2k
    Gabi N, este un SUPER OM
    S-a purtat exceptional si cu mine.. si mi-a rezolvat o problema de electronica destul de grea
    Eu il stiu din alta parte.. dar vad ca l-am gasit si aici..
    Toate respectele pentru Gabi
  1. Loader Humax gresit
    By Dumitru in forum SD Receivers
    Last Post: 21st April 2006, 08:53
  2. Firmware pentru DVD Player Orion ISP: Ajutor!!!!!
    By Pete in forum DVD - DIVX - HIFI
    Last Post: 14th January 2006, 14:12
  3. Nota 24 - smart card introdusa gresit!
    By vasiletina in forum DTH & Cable-Romania
    Last Post: 22nd September 2005, 11:37
  4. HUMAX BTCI 5900- SOFT GRESIT PUS (S.O.S.)
    By LAURI in forum SD Receivers
    Last Post: 10th September 2004, 16:19
