    Jul 2006
    Timisoara, RO
    Default EIRP values and dish size for Ku-band
    Here http://www.satlex.net/en/eirp_values_ku_band.html it is given a table for the dish size vs. EIRP values, for an universal LNB 0.7 dB.
    What would be the difference in dish size for a LNB of 0.2-0.3 dB?
    Thanks in advance.
    the difference is negligible. besides, most of these .2/.3 labels are simply that... labels. performance wise, always anticipate for certain fluctuations on signal quality even if you base your calculations on that kind of chart. get a big dish, bigger than the suggested size then only you can benefit from a good, stable signal.
    Jul 2006
    Timisoara, RO
    @boknoy_ph
    yep I figured. I was thinking if with a 120 cm dish I have chances to see a sattelite with a reccomended dish of 135 cm.
    with very steady hands, you just might be able to get the signal, if you are lucky to have out-of-footprint-side-lobe signals.
  1. Replies: 1
    Last Post: 18th August 2006, 05:05
  2. Replies: 0
    Last Post: 22nd July 2006, 03:06
  3. Dish Size Chart
    By Anver in forum RDI - English
    Last Post: 8th July 2006, 20:52
  4. dish size
    By peterm165 in forum RDI - English
    Last Post: 23rd June 2006, 16:44
  5. dish size on turksat in kuwait?? help me out plz
    By nightrider083 in forum RDI - English
    Last Post: 5th January 2006, 23:38
