    w00t Teacher
    Horsens/Denmark
    Default Probleme cu Prog DVB 4.72 si urmatoarele versiuni
    NU stiu de ce dupa ce instalez prog dvb, intru in el, ma uit...nici o problema
    dupa ce dau pe "x" sau close imi apare eroarea...
    o eroare si imi apare "don't send"...
    ce pot sa fac sa fie de la windows
    am windows xp cu sp3
    BUZAU
    Error signature
    AppName: progdvb.exe AppVer: 4.0.0.0 ModName: skystar2.device
    ModVer: 0.0.0.0 Offset: 00002230
    ..si la mine la fel....am reinstalat chiar XP cu SP2 (nu din acest motiv)....si nu a mai aparut eroarea...apoi am facut un Windows Update....si iar a aparut...am vaga idee ca ar fi deci de la un update la win...
    Optibox Spider HD
    HSS-7160NA (DigiTV)
    90E - 34,5V
    w00t Teacher
    Horsens/Denmark
    mie nu imi apare nici o explicatie
    imi apare fereastra aia de la windows si zice ca e o eroare... jos ai 2 casute
    "send report..." si "don't send"
    BUZAU
    Quote Originally Posted by emyklaudiu
    Explicatia iti apare daca in acea fereastra apesi pe click here..
    Optibox Spider HD
    HSS-7160NA (DigiTV)
    90E - 34,5V
    w00t Teacher
    Horsens/Denmark
    nu am incercat niciodata sa dau pe click here...
    multumesc
  1. probleme codecuri prog dvb
    By pauldemon in forum Placi DVB
    Last Post: 24th May 2006, 10:26
  2. broadlogic 2030 prog dvb si probleme
    By nirolf in forum Placi DVB
    Last Post: 12th February 2006, 23:33
  3. GS versiuni noi
    By energyps2 in forum SD Receivers
    Last Post: 31st May 2005, 14:03
  4. Versiuni noi la
    By yo7cjf in forum Placi DVB
    Last Post: 27th July 2004, 23:58
