    Apr 2006
    Default SATELLITE SIGNAL GO THROUGH GLASS??
    Plz confim, is it possible to transmit or receive satellite signal through wibdow glass or net?
    If possble one can easily install dish inside room and geting signal trough window glass!
    Enjoy while FTA....................
    Africa-Kenya-Nbi
    Default Re: SATELLITE SIGNAL GO THROUGH GLASS??
    Quote Originally Posted by satpalchat1
    through reasoning the satellite beam is received on the dish at an angle of more than 150 degrees, you do not only need the window if the glass is passive to the signals, but also a glass roof to attain the required angle of reception.
    please do the experiment but remember, only a cannopy on top of the dish will block reception, so how about a roof on top of the dish.
    maybe in extreme cases, with a prefocused small dish say 100cm you can experiment on glass. start with a glass house, the prefocused requires a lesser angle.
    Dstv HD PVR
    Apr 2006
    thanks for info. I got some article done by some experimentist, link below
    http://www.selkirkshire.demon.co.uk/...indowdish.html
    Africa-Kenya-Nbi
    thanks for the ref. i find it possible with strong signals, and this means you have to know the sat you are looking for to be accesible through the same glass window direction.
    this is extreeme cases, though not the best.
    at least something is better than nothing. I will experiment too
    Dstv HD PVR
  1. Any tool to find Satellite Signal in Real Time ?
    By urpradhan in forum RDI - English
    Last Post: 21st December 2006, 19:03
  2. Any FTA HD H264 satellite signal?
    By Rotita in forum RDI - Satelit
    Last Post: 10th April 2006, 17:25
  3. SATELLITE SIGNAL THROUGH INTERNET
    Last Post: 3rd January 2006, 10:19
