Results 1 to 14 of 14
    pakistan
    Default I NEED CARD SHARING SERIAL NUMBER ANY BODY HELP ME
    ANY BODY HELP ME I NEED CARD SHARING SERIAL NUMBER FOR MY (STAR TRACK 550D)I HAVE SOFTWARE BUT NOT HAVE SERIAN NUMBER PLZ GIVE ME AND GUIDE ME WHICH WAY I CAN USE
    i want to know that i can wacth
    Lahore
    Default Re: I NEED CARD SHARING SERIAL NUMBER ANY BODY HELP ME
    Quote Originally Posted by jeemeherjee
    If ur STB supports CS and you want to share in FREE?
    If no then contact to Usmanlahore for more detail.
    Fte Max 100S
    Humax IRCI-5400z
    pakistan
    YES MASSOD MY RECIEVER SPORT CARD SHARING AND I HAVE SOFTWARE IN MY COMPUTER WHICH LINK BETWEEN COMPUTER AND RECIEVER BUT I DID NOT HAVE SERIAL NUMBER EHICH IT VARIFY IF SOME ONE HELP ME I AM VERY THANKFUL TO ALL
    Nov 2005
    try this S/N 00000301992807294.
    swabi pakistan
    hi
    can u give me the link or software for card share from computer to reciver and also the way to enter the s-no.My email is [email protected]
    thankx
    pakistan
    thanks for giving me s/n it is working right
    afxal
    jeemeherjee where did u downloaded this software? i also want this software.Please post the link or e-mail me : [email protected].
    UN KNOWN
    Jul 2006
    Saudi Arabia
    Dear mr.DISH we need password and username to download.please provide that too.
    thnx
    tufail
    Dreambox Dm 500
    Nilesat,PanAm sat 7/10,Paksat 1,Arabsat,Hotbird
    Nov 2005
    tufail 74 wll come back...
    no need of username and password for the link above..
    so what happend to your micro-x sharing still working or
    not?.
    May 2005
    Default Help please
    Quote Originally Posted by akkj
    not?.
    Please tell me, I downloaded all the files from the above link but once I start the program it hangs up the computer specially when I enter the serial number and press connect. (S/NO 00000301992807294)
    1- Also tell me does it work with all receivers?
    2- Which software should be on the receiver?
    3- My receiver is technosat 6000plus. Connected with RS232 cable.
    The software is S2 7.91.
    Thank you all.
    Nov 2005
    if you have receiver ,,,startrack 550d or neosat 1600 plus,
    truman 150, mx reader fta and some other receivers please
    use this client which you downloaded from above link is,
    a_online_2 .unzip it and install it into your computer.then
    turn on your stb press menu >installation>card share>xshare>
    S/NO 00000301992807294.ok
    hurry up coz most of the xshare channels are gone .
    pakistan
    card sharing program has some problem after some time of working it say program close because of wrong opration what is that problem
    swabi pakistan
    plz some one tell me the server ip and id number
    thanks in advance
  1. Need Avid Liquid HD 7 Serial Number
    By droshan in forum RDI - English
    Last Post: 19th December 2006, 09:28
  2. serial number ptr.FastSatfinder?
    By prostescu in forum RDI - Satelit
    Last Post: 2nd December 2006, 08:20
  3. Pehla Plus Expire smart Card Number Requried plz
    By fairman in forum RDI - English
    Last Post: 8th December 2005, 07:31
