Results 1 to 10 of 10
    In a Weird RooM
    Default AesDirekt not working for tps on humax5400z
    givin following error not even old version is working anybody can give solution..? or any other way for tps..?
    babaji, it's working fine with me, I'm using the version 2.3 with today's updated keys.ini and AESDatabase from mach 1
    In a Weird RooM
    Quote Originally Posted by tomultra
    both versions r not working viakey:08 is coming all the time..
    Aug 2002
    Default Re: AesDirekt not working for tps on humax5400z
    Quote Originally Posted by baba4u
    why did you leave your box idol for 56 days?
    In a Weird RooM
    Quote Originally Posted by satlover
    56 days 5 or 6 :P
    ALIBE
    To get AES Direkt working:
    Double click on file Keys.ini
    Delete line:
    1=http:**********************.php
    Insert line:
    1=http://vhmtraq.prophp.org/aes_type/linuxkeys.php
    Save changes and run AES Direkt.
    Hopefully, it should now work.
    In a Weird RooM
    Quote Originally Posted by ALIBE
    Delete line:
    Insert line:
    this site is already mentioned in the key.ini file but still tps is not working...
    hi friends
    it is ok with AESDirekt2.8
    s a j i d f i n e
    ALIBE
    I have tried AES Direkt 2.3, 2.6 and 2.8 and all are working for me.
    If adding a new Web address to the key.ini file did not solve the problem then you could try the following.
    1. Re-extract the files from your original zip file and over-write the existing ones.
    or
    2. Delete ALL the data stored within the following files
    AESDBASE.txt
    AESUPDATE.log
    FAILED_DES.txt
    Do not delete the files themselves as new data needs to be written to them.
    Edit the Keys.ini file by deleting the existing AES key.
    Example
    Current:
    CRYPTKEY=BA7A03EC435AE3BBAB4B34C42E15109D
    After Edit
    CRYPTKEY=
    Save the files in the edited format.
    Now, when you run AES Direkt it is forced to look for an AES key on the internet.
    I hope this works for you.
    In a Weird RooM
    thanx dude for helping aesdirekt 2.8 is much stable as i just used yesterdat night...
  1. tps stops working on humax5400z
    By baba4u in forum RDI - English
    Last Post: 22nd September 2006, 00:47
  2. humax5400z
    By sanil in forum RDI - English
    Last Post: 4th September 2006, 01:46
  3. AesDirekt 3.4 with keys database(tps)
    Last Post: 22nd August 2006, 21:30
  4. humax5400z.......
    By belloonline in forum RDI - English
    Last Post: 1st June 2005, 21:09
  5. Humax5400z si DTH
    By palazzo1974 in forum DTH & Cable-Romania
    Last Post: 4th March 2005, 20:02
