Results 1 to 3 of 3
    Default help in entering key,
    Hi,..
    I am using sratsat SR-X50CU and I wanna know can I use keycodes ?
    I have downloaded receiver upgrades from http://www.satdw.com/ and upgraded my receiver successfully , but I don't know how to use keycodes, such as in http://www.********.com/f2/viewtopic....er=asc&start=0
    I mean how can I enter these codes in my receiver ?
    I also heared about softwares such as dreamloader, but I coudn't find any hex files appropriate for it, I wanna ask what's the difference between the codes above and this software, how to use it , and where to find the hex codes suitable for my sat ?
    I appreciate your help,
    thanks a lot,
    Sincerely,
    Africa-Kenya-Nbi
    If you can get to code menu, with the same instructions downloaded with the software then you can insert or load the software,
    more difficulties youd be helped by a starsat user in forum.
    Dstv HD PVR
    dear buddy ,
    the problem is that I cannot find any code menu inorder to enter the codes,
    on the other hand I cannot find any appropriate hex files inorder to use softwares such as dream loader,etc
    If anyone knows how to enter the codes in SR_X50CU, please post it here ,
    thanks a lot ,
  1. Entering Prem**Re keys
    By czechrite in forum RDI - English
    Last Post: 22nd August 2006, 20:48
  2. Entering B4U Movies key to Dynasat
    By SumitB in forum RDI - English
    Last Post: 15th August 2006, 19:21
  3. help entering keys
    By G E R in forum RDI - English
    Last Post: 4th April 2006, 15:14
  4. Entering AES key to Kopernikus receiver
    By iamtree in forum RDI - English
    Last Post: 21st December 2005, 21:07
  5. Entering the keys
    By pahmadi in forum RDI - English
    Last Post: 5th November 2005, 01:13
