    Default BeSat 2400 SUPER GOLD (USB port), please help
    Please help me,
    I’ve Besat 2400 super gold Receiver. It has an USB port; can u tell me what this for?
    It doesn’t have any 12v out port, then how I will use more than 4 LNB on this Receiver. (Here in my area there is no 8 port DiSEqC).
    Default Re: BeSat 2400 SUPER GOLD (USB port), please help
    Quote Originally Posted by kazalmahmood
    Please help me,
    the usb port is being used for video link funtion so that you may watch the reception from your pc. install the necessary software that came along with your unit.
    as for the disecq switch, you can use a manual A/B port switch (that is the cheapest solution) or if you want, but a multiswitch like Spaun (expensive).
    Thank u boknoy_ph.
    I get this receiver by my friend, and don’t get any documentation and software. Can u kindly give me any link on web, to download the software plz. I will be very grateful to u.
    I find ASAT DiSEqC 1/10 SWITCH & EMP-Centauri S168 8in1 on web, are they work? or available in Jeddah, K.S.A?
    Or, If I use external 12v to the switch, will it work?
    boknoy_ph? any one who can help.
    yes, they will work. but im not sure about the availability. why not visit your satellite shops in the area and look for chinese made multiswitches. im just wondering what those 8 satellites you are trying to obtain?
    Thanks boknoy_ph.
    I’ve obtained Hot Bird, PAS 7/10, Nilesat, Thaicom 5, Telstar 10 & AsiaSat 3S.
    I also tried Hispasat & Eurobird1 but failed (I live in Makkah). What about the
    software, can u give me any link?
    if you have MTG installed on it, go for metadream. if Dreamsoft is already installed, then simply reinstall the latest patch from dreamsoft. although there is nothing to watch nowadays on encryptions and the TPS pc updater are still buggy (sometimes works on metadream softwares), so if i were you, i'd hold off updating the box as of yet. anyway, softwares are available at www.pinoycourt.com
    Thanks, I'll try...
  1. besat 2400 super gold
    By anjum73 in forum RDI - English
    Last Post: 3rd September 2006, 12:34
  2. besat 2400 super gold needs upgrade
    By wbvilla in forum RDI - English
    Last Post: 21st July 2006, 20:10
  3. Besat 2400 super gold problem
    Last Post: 28th November 2005, 05:37
  4. besat 2400 super gold & Dream TV AU
    By randy in forum RDI - English
    Last Post: 17th October 2005, 19:48
  5. Besat 2400 Super Gold and Dr**m TV
    By kevo in forum RDI - English
    Last Post: 2nd October 2005, 16:02
