Results 1 to 12 of 12
    bijitha
    Default c band signal problem
    i am facing problem from c band signal ( asiasat , insat ) most of the time chanels from these satellite cutting. ( picture and sound ) some time only getting clear. dish and lnb tunning everything 100% ok. no problem in ku band signal. any one can replay to solve this problem.
    thanks
    Aug 2002
    Default Re: c band signal problem
    Quote Originally Posted by bijitha
    thanks
    DiSEqC switch must be malfunctioning
    these days these i m also having these sort of problems ............ may be it is due to the weather ........ rains rains rains ...... and moisture .........
    may be it can have an effect on the internal Diseq part
    hope ur and my problems are solved ............
    Apr 2005
    Myself also experienced the same problem before in Insat 2E
    I'm living in a Township.
    Inside our township there is a Military Radar tower.
    Everyday around 10 AM , the picture starts freezing and cutting out and in.
    Sometime it lasts upto the midnight.
    I tried Different Diseq, different Receiver. But results were same. Only thing was the disturbances were little in some receivers.
    Once I changed the location of my house, all the problem sorted out automatically. Still I'm using that old Diseq.
    We r suspecting, it was due to the military radar. May be some frequency conflict.
    Still it's a mystery
    DISH CITY Teacher
    India
    Hello friend ,
    I am also facing same problem in receiving single channel in some satellites; but multiple chanels in same freq., is ok it is due to rain. This problem occurs in heavy rain fallig areas.Slightly rotate your feed horn position and try this method may help you. And make sure that is any power line is near by your receiving sight it also causes signal loss.ALL THE BEST
    Megahertzpark
    there have been reports that even wifi devices can kill the cband signals (read it somewhere on an australian forum).
    SATELLITE GURU Expert
    Yep Vetruns....
    But you can buy a microwave filtered LNB but they do cost a bundle...
    bijitha
    thanks for all replays, but any one can give final solutin, please
    Yep get a bigger dish and fine tune your lnb...
    Lahore
    the final solution to find smooth signals ,,,,check all things ,are described in above posts by various experts.
    what is your finding? did you check by replacing DiSEqC switch?
    Is there any booster or radar as camelot argued?
    You have to decide by urself where is "loosing"
    Fte Max 100S
    Humax IRCI-5400z
    bijitha
    i check diseq, lnb and every thing, i chack with different receivers, i am using dvb card also same problem. i have doubt abot other signal like rader and etc, so any solution for this problem.
    Friends
    Use single solution LNB it will be ok
    (my experience) I am in UAE
    ghosh
  1. INSAT3B/4A 83DEG KU BAND SIGNAL IN DUBAI....
    By dj mufty in forum RDI - English
    Last Post: 25th November 2006, 20:03
  2. signal problem
    By rajashery in forum RDI - English
    Last Post: 9th June 2006, 22:04
  3. Insat4A Ku band signal in Oman?
    By rishi in forum RDI - English
    Last Post: 17th May 2006, 21:11
  4. I HAVE SIGNAL PROBLEM
    By jeemeherjee in forum RDI - English
    Last Post: 29th April 2006, 12:34
  5. SIGNAL PROBLEM ON HOTBIRD
    By nazaks4 in forum RDI - English
    Last Post: 29th March 2006, 14:57
