    Default B4U MOVIES KEY PUTTING PROBLEM IN DIGITALLWORLD RECEIVER
    Dear Friends,
    I have Digitallworld SCI 190 Receiver. When I put Keys for B4U Movies so it open it. But when I turned off the receiver It locks again and It shows another key instead of Key which i have put....but when i put the correct key again it opens the channel....but when i turned off my receiver the same problem again happend....So please suggest me a sulotion for it...
    Looking for a prompt reply...
    Thanks and regards,
    MAJID KHAN
    PESHAWAR, PAKISTAN
    Hello friend,
    use softcam editor and pc to load the softcam keys manually.I had the same problem on sft2000m
    dugizul
    Thanks alot friend...but where i can download Softcam Editor
    thanks and regards,
    Majid
    Aug 2002
    Try to download keys after factory default setting
    Thanks friend i will check the method ....
    Thanks for quick reply
    MAJID
    Dear Friends,
    I have applied both the methods but nothing positive,,,,i tried softca editor, and default sitting methods but my problem didnt solved....
    So please solved my problem ....any other way..
    Thanks and regards,
    MAJID KHAN
    PESHAWAR
    Quote Originally Posted by majidpsh
    Dear Friends,
    Thanks and regards,
    MAJID KHAN
    PESHAWAR
    please chech your pm
  1. b4u movies on digitallworld
    By bublu in forum RDI - English
    Last Post: 25th June 2006, 22:39
  2. Replies: 1
    Last Post: 25th June 2006, 15:42
  3. Replies: 1
    Last Post: 26th November 2005, 11:10
  4. PROBLEM DIGITALLWORLD SCI 190
    By homax8585 in forum RDI - English
    Last Post: 25th November 2005, 04:03
  5. Digitallworld SCI 190 Channels Problem?????
    By majidpsh in forum RDI - English
    Last Post: 10th October 2005, 14:24
