Results 1 to 10 of 10
    Jul 2006
    Default Please help...freuency/LNB problem
    I am unable to receive channels with frequency above 10000 (10970-12722) from PAS10 sat. What should I do?.
    21.95° N 97.06° E
    Default Re: Please help...freuency/LNB problem
    Quote Originally Posted by scorpionz
    Dear friend, what LNB r u using now,KU or C-Band LNB?
    Thanks.
    " 李俊明 Born To Help People "
    Jul 2006
    I have a motorized 8 ft dish wih two LNB's, Neosat C-Band Universal LNB and Startrack Ku-Band Universal LNB. I get all the channels with less frequency by using C-Band LNB, but cant get these bigger frequency channels. If I use Ku LNB i cant get signal. Please help.
    SATELLITE GURU Expert
    Perhaps your LNB is 11300 which cannot receive the lower freqs for that you'll need a universal with 9750 10600
    canine consultant Expert
    have you changed the setting in the menu on your receiver for the universial LNB
    Go to Antenna set-up, and load 9750 low and 10600 high, or select the universial setting.
    regards from OZ bassett
    Jul 2006
    Yes brother but to no avail. Please look at these images and you'll know my problem.
    http://img15.imgspot.com/u/06/205/03/11153813229.jpg
    http://img15.imgspot.com/u/06/205/03/21153813387.jpg
    Waiting impatiently.
    21.95° N 97.06° E
    Dear scorpionz, Sir I2E had been told u that u need to change Low/High Lnb setting.U must change "Type" to Universal or change "Low Freq" to 9750 and "High Freq" to 10600.Then u will get what u want....
    Hope this will help.
    Jul 2006
    No difference at all brother, you can see, no matter which transponder I select.
    http://img15.imgspot.com/u/06/205/05/31153819290.jpg
    21.95° N 97.06° E
    Have u try with another Universal LNB ?
    Aug 2002
    which channels you want to watch?
    As yan naing pointed out ,you need to configure antenna setup accurately
  1. VERY SERIOUS PROBLEM.
    Last Post: 27th July 2006, 02:16
  2. Problem about hot 6.9
    By spot1bay in forum RDI - English
    Last Post: 15th March 2006, 13:25
  3. Log in problem
    Last Post: 18th November 2005, 17:12
  4. @ problem
    By msalman in forum RDI - English
    Last Post: 30th July 2005, 08:13
  5. Problemă !!!
    By skycleaner in forum DTH & Cable-Romania
    Last Post: 20th July 2005, 17:22
