Results 1 to 2 of 2
    Jul 2006
    Default Strange signal problem. Please help!!
    Hello,
    I've tm 1500 ci, an Invacom Lnb and a Motec Motor. For last few days I'm experiencing strange signal problems.At night I loss signals on any transponder (v)upto 11.700 frequency on any sat. I also loss some of Horizontal TPs too. At day time the same TPs are back to normal with good signal. For example I loss tps, at 13 deg east, at night and in day time it's back with good signal. I have also noticed when I switch on and off the stb, sometimes signal comes back but slowly it goes down to red. Any help and advice to sort out this problem would be greatly appreciated. Thank you.
    selim_uk you do the fol
    1. change the connectors
    if prob still is there then change the complete wire from LNB till your STB. I also had the same prob but solved now.
  1. Strange problem........please help
    By scorpionz in forum RDI - English
    Last Post: 27th November 2006, 22:40
  2. Strange Problem
    Last Post: 21st July 2006, 07:51
  3. Strange Problem
    Last Post: 20th July 2006, 23:53
  4. Strange Problem on HOTBIRD! Please Help
    By usmanmr in forum RDI - English
    Last Post: 29th April 2006, 21:57
  5. help admin : strange login + post problem
    By superia4u in forum RDI - English
    Last Post: 13th August 2005, 14:49
