Results 1 to 3 of 3
    Jun 2006
    u a e
    Default EXPERTS PLZ. HELP
    dear experts,
    my upgrade problem for neosat sx9800ci still remains. plz help!
    i have downloaded the correct software from a site. it was written (new software for neosat sx9800ci). it was a zip file. i extracted it there were three files in it. these were the files :
    1. boot-sx9800ci-05oct04
    bin file
    8kb
    2. sx9800ci-05oct04
    bin file
    661kb
    3. upgrade
    serial mfc application
    the bin files doesnt open the system says says it needs a prog. to open....search the web for appropriate prog.
    and when i open upgrade file this window comes out:
    com 1 , 11500, connect
    load
    i clicked connect the load but its not loading.
    is it b`cos the cable is not working b`cos in my rec. there is port rs232c
    any difference between rs232 and rs232c
    pls. reply soon
    thanks for ur fast and future replies
    Pakistan
    Make sure that your cable has the following configuration
    2----3
    3----2
    5----5
    And if you have already a Neosat SX9800 software(Not a Clone S/W like Starsat 8005d) then no need for a boot file
    Simply "Browse" the s/w .bin file , Click on Connect ,and "unplug & then plug again" your STB....
    lt should start loading...
    az30094
    @ganouk
    bin files are binary files. You need a Hex editor to view them. Normally, you don't need to, unless you want to see its contents et al.
    The other executable file is the loader. This you need to download the above bin file into your receiver.
  1. TO ALL EXPERTS, NSS/6
    By j2j in forum RDI - English
    Last Post: 22nd November 2006, 05:16
  2. Where are the Experts???
    By kamban in forum RDI - English
    Last Post: 11th July 2006, 06:54
  3. experts please help
    By sahiasia in forum RDI - English
    Last Post: 17th June 2006, 01:37
  4. RDI-EXPERTS..help
    By dawar098 in forum RDI - English
    Last Post: 29th May 2006, 00:31
  5. 2 all the rdi experts can u help me out....
    By dj mufty in forum RDI - English
    Last Post: 13th March 2006, 16:29
