Results 1 to 10 of 10
    Apr 2006
    Default " Pehla" expert's help required
    I had Pehla subscription which is expired, i don't have any intention to renew, now even, i can not watch FTA chanells. is there any possibility to watch FTA chanells using same receiver.
    -- Humax IR-ACE SII
    Appreciated your's kind help.
    May 2004
    Kuwait
    this receiver is programmed by the service provider thats Y they offered it in cheap so that when its services r expired u have to renew.If u program it by ur own self u might get the FTA channels but u wont get pehla package in future and the pehla service ppl might fine u for the programming if u r suppose to return the receiver when contract was signed.
    Apr 2006
    Quote Originally Posted by lovebird
    Thanks, i don't have any contract to return, how i can change Humax software to view FTA chanells, Thanks
    Jun 2006
    You can watch FTA Channels without modifying software. Were you able to watch any FTA channels when you had the Pehla subscription. If yes then something is wrong with the software. If no then you have a single polarity LNB i.e. Pehla broadcasts all channels on Horizontal frequency and most of the FTA Channels on Nilesat are on Vertical/Horizontal. The single polarity LNB does not allow you to switch from Horizontal to Vertical as it can only allow either H or V, so try changing the LNB to a Universal LNB this will help you to get the FTA Channels back. Go on the roof and check, the LNB clearly states if it is Universal or allows one polarity
    95° East
    Default Re: " Pehla" expert's help required
    Quote Originally Posted by SHY
    -- Humax IR-ACE SII
    Dear,
    Same thing happen to me before, you don't need to return the Dish or STB it is all yours and you paid for that.
    Did you check the configuration or LNB - Get a Universal LNB
    Regards
    Apr 2006
    Quote Originally Posted by RM1296
    I'm greatful for your kind attention, When i had Pehla subscription i was able to watch all FTA chanells,I never noticed about Polarity, so if LNB is not universal, then i shall be able to view V polarity chanells,I can confirm the LNB an comeback to u.
    so sorry to hear this, you will be not able to watch fta channel, until u renew yr subscription on same card.
    i have DSD 900Z and when mine subs expired my receiver also locked, even i put my friend card [not mine card] it did not shown fta channel,
    i checked everything softs etc... but NO
    then i renewd my subs and it works all, it doesnt matter POLARITY V / H
    Aug 2004
    M east
    It is better to return the stb to the pehla dealer or if any one to watch intersting pehla channels.The main problem the stb maintained by the card which has no subscription its not work. the humax service center can do the problem to change the software .
    Tech
    Sep 2004
    Default dear
    dear u can watch free chanles on this receiver with out upgrade any software
    1st open ur receiver front panel plat
    then see on plat near grip wire 2 smal solder points . conect the
    booth points with solder gun . now that is ok 100%%%%%%%%%
    Nov 2005
    KSA
    im surprised how misguided some members here are. not only that you are trying to misguide genuine questionners aswell faisalramzan ?
    SHY you cant watch the free to air channels now coz the software restricts you from doing so.......... thats how ART, SHOWTIME and PEHLA are programming their receivers now.
    regards
    STB info:
    Humax5400 with ****** FREECAM 2-019, Coship, Manhattan Plaza ST550 PVR with 80GB Maxtor Quickview HDD.
    Dish Info:
    HotBird,NileSat;ArabSat;Panamsat-10,AsiaSat3s
    Subscriptions:
    Showtime,Pehla
  1. Iara cu " sorcova " adica cu " Cine Stie ? &
    By nikos in forum SD Receivers
    Last Post: 11th October 2006, 10:33
  2. "lost","prison break",bollywood music ch
    By cokeman in forum RDI - English
    Last Post: 6th July 2006, 16:56
  3. Canale HD la "radio", "data" in ALT-DVB
    By Medox in forum Placi DVB
    Last Post: 13th May 2006, 08:07
  4. Auvisio 3,5" HDD "Media Box" inkl 250GB Festp
    By valentino in forum DVD - DIVX - HIFI
    Last Post: 14th February 2006, 15:09
