Results 1 to 3 of 3
    Default Technosat Receiver 6000+ help needed
    hi
    can any1 tell me, how can i enable key editing in Technosat Receiver 6000+
    its a three card slot receiver and i wanna can i enter keys for srg, slv etc... to get those channels...
    thank u
    Kuwait
    first update latest software from www.dsrsoftware.com
    This should enable SF2, multivision, etc at the moment. After installing the new software to your box, enter the menu, go to user settings, then parental control. enter the parental control using password 0000. Change this password to 9911.
    After doing this, exit parental control to allow your box to save the changes, then go back to preantal control; you should see "press red to enter key manager". if not, enter the code 9911 again and it will appear. press red on your remote to go there, select the keys you want to update and away you go!
    Default thanks
    thanks...
    i will try, wht u said n let u know d result.. thanks
  1. technosat 6000 plus problems with Sahara one access card
    By khal_nayak8 in forum RDI - English
    Last Post: 17th April 2006, 10:49
  2. Technosat 6000 Plus
    By amanites in forum RDI - English
    Last Post: 10th March 2006, 16:26
  3. Technosat 5500 and 6000
    By coolestteacherever in forum RDI - English
    Last Post: 20th November 2005, 03:26
  4. Technosat 6000 plus
    By onin in forum RDI - English
    Last Post: 11th November 2005, 19:50
  5. I need to Know about Technosat 6000 Receiver
    By soofi in forum RDI - English
    Last Post: 27th May 2005, 09:11
