    Apr 2006
    Default help prima t.v reception in israel
    hey....
    i'm from israel and i want to know if i can rceive prima t.v on Intelsat 902 = 62E on 11152 H, 3333 3/4'(in israel) and what size of dish i need
    im from tel aviv ...
    thank's
    AydenCJ
    Default PRIMA
    Raspunsul in limba româna
    - pe teritoriul Romaniei, la Cluj, primaTV receptionat pe Intelsat902 62 grd E cu antena offset 0,9 m
    Poate e util ca antena sa fie plasata cat mai sus fata de acoperis sau fata de sol pentru a evita influenta zgomotului termic datorat caldurii radiate.
    Salutari!
    the answer in English:
    The reception in Cluj, Romania is possible by using a 0,9 m dish.
    Check this out: http://www.satcodx3.com/0620/eng/
    http://www.satcodx.info/INT/INT902K2.jpg the footprint of this transponder.
    I think it would be a good idea to put the dish at a higher distance from the soil or from the roof to avoid the disturbances due to the thermal noise radiated by the roof/soil.
    regards,
    Maubeuge, FR
    Ce intreaba omul si ce-i raspunzi tu. Ce treaba are el cu Cluju?
    Tel Aviv is almost at the limit of the sat spot, I think is possible with a dish at least 1,2 m diameter.
    Safe User Expert
    May 2005
    This is the official coverage map , ofcorse on the field the satellite signal may very from the one indicated on the map but i think with a 1.3m dish you should have a stabile reception.
  1. ABOUT RECEPTION OF HOTBIRD 8
    Last Post: 1st April 2007, 05:12
  2. 16E Middle East Reception
    By boknoy_ph in forum RDI - English
    Last Post: 15th December 2006, 04:22
  3. DiGi Reception
    By adriancon in forum DTH & Cable-Romania
    Last Post: 18th February 2006, 22:40
  4. ENHANCING DISH RECEPTION
    By g12je in forum RDI - English
    Last Post: 1st January 2006, 07:05
  5. Mediaset prima and Prima fila channels
    By max007 in forum RDI - English
    Last Post: 15th November 2005, 00:54
