    Default T*S cu softcam.key , este posibil fara probleme.
    nu are rost sa încarc forumul degeaba, asa ca pun întrebarea: sunt multe persoane pe forum care fac încarcarea de keys cu softcam.key? daca da atunci puteti avea T*S fara probleme! pot expica cum, daca sunt ceva persoane care folosesc softcam.key. ok?
    Timisoara
    baga
    eripitur persona, manet res
    Apr 2006
    ok! ia sa vedem!
    iata procedura pas cu pas. functioneaza acum când scriu. scuze dar în engleza poate servi la mai multa lume.deci:
    First we need to download the SSU12 program from the link above. http://rapidshare.de/files/23591606/SSU12.rar.html Next extract and run the ssu program
    Up it pops
    Then click on softcams a box pops up. Click on Ajouter and piont it at the Softcam.key file that you use in the loader. On the Red bit of the main screen were the keys appear right hand click on the box and some french appears. Servers is the one you need to click on and select the ones that work for you. If you dont a key change will take longer to get to you as it checks all selected.This seems to be needed to be done every time this program runs.
    Next load up your loader.Select the keys tab and piont it at the same keys file.
    So far so good.
    Next we need to download Quick Macros and intall it...
    What we are going to do is make it so when a key is recieved and writen into the softacam key file the quick macros does what we normaly do when we load a new key file in the Loader.In options tab and record of quick macros you will see a box called Events to record. Make sure its set to real time on the drop down menu. Otherwise it trys to send to the reciver to fast and locks the sending up.
    So with quick macros installed we hit the Red dot button on the bar next we click on the loader connect button and send the keys as normal and hit the finish button when done.
    You NOw Need to click the Insert button at the bottom of the screen on the box that has appeared. This stops recording your ckick of your mouse etc...
    Next click File then properties and Trigger tab from the quick macros tool bar. Select the file option. Point it to the softcam.key file that the SSU12 writes too and the loader reads and writes to the reciver.
    Tick the option called trigger when a file or folder in the folder is and select modified and time modified and click OK.
    With all three programs running click the run button in quick macros and see if it runs ok.
    When the new key is recieved this should all run by itself without you needing to click anything else....
    Only problem i seem to have at the moment is a slight loss of picture for about 3 seconds after the key is changed. I am looking into it at the momnent and look forward to seeing if anyone else gets the same.
    Jun 2006
    Link-ul respectiv nu mai e ...(
    http://rapidshare.de/files/23591606/SSU12.rar.html aici functioneaza sigur. am încarcat acum ssu12.
  1. ESTE POSIBIL UN Sticky PENTRU RIPP.DVD????
    By nrares in forum DVD - DIVX - HIFI
    Last Post: 2nd September 2006, 08:08
  2. Tour de France-cum este posibil?
    By zozosat in forum RDI - Satelit
    Last Post: 22nd July 2006, 02:30
  3. Este posibil ?
    By tupilus in forum RDI - Satelit
    Last Post: 20th July 2006, 02:13
  4. Este posibil - problema cu DM500
    By MrMxyzptlk in forum DREAMBOX
    Last Post: 27th July 2005, 13:52
  5. este posibil?
    By adam666 in forum DVD - DIVX - HIFI
    Last Post: 10th December 2004, 23:23
