Results 1 to 10 of 10
    Apr 2005
    Default Need advise from Experts
    Dear Friends,
    I would like to make or purchase a lengthy RS 232 cable of around 10-15 Meters. One of my friend he expressed his doubt about the length and data transfer. He told the data(signal) may not reach upto the end point in some occassions.
    Anyone has experienced with a lengthy cable?
    Please advise me.
    thanks in advance
    95° East
    Dear,
    10 Mtr is OK, but not tried with 15 Mtr.
    Regards
    Lahore
    Quote Originally Posted by Anver
    Dear,
    10 M is much much more ,,your doubts are 100% correct.If the wire quality is extra good then it is possible to communicate data otherwise not possible
    Fte Max 100S
    Humax IRCI-5400z
    Maseru, Lesotho
    I have run almost 25 M using cat5 network cable, worked fine
    95° East
    Quote Originally Posted by Boknaaai
    Dear
    He is asking about serial cable RS232 not the CAT5 cable that can more than 90 mtr
    Regards
    Maseru, Lesotho
    Dear
    I am Talking about RS232 (You know from the PC serial port to the other device, DB9 pin 2,3 and 5)
    I just happened to use cat5 cable as it was in great supply, as I said it worked fine almost to 25 M
    May 2004
    yes, max 30 feet or 10 meteres, more length is not guaranteed, but you can give it a try, may work if your cable quality is realy good and no other obstacles.
    az30094
    Boknaaai is right. RS232 cables can run into longer lengths without any problems. If the environment is noisy (electrically), then it is recommended to use a shielded cable. Otherwise, a normal cable is enough. I have used 50 mts. length of cables in industrial environment without any problems.
    Jun 2006
    Default NOT WORK
    YES IT IS TRUE IT WILL NOT WORK
    Apr 2005
    Thanks all
    Finally I got it. Now my cable length is 18Ms.
    It is working well. It is a good quality shielded cable by Alcatel.
  1. need help and advise please
    By andycyp in forum RDI - English
    Last Post: 29th June 2006, 00:56
  2. Receiver Advise...
    By fjsatman in forum RDI - English
    Last Post: 5th April 2006, 11:22
  3. I went through your answer and advise
    By sunair_h2o in forum RDI - English
    Last Post: 15th January 2006, 00:00
  4. experts please
    By irshad in forum RDI - English
    Last Post: 21st August 2005, 04:23
  5. Advise in netion SHl Sky chip Stb
    By Aliraza63 in forum RDI - English
    Last Post: 22nd May 2005, 16:59
