Results 1 to 2 of 2
    Jun 2006
    Default I think I need help
    I'm pretty new to changing codes etc. I have tried the TPS codes that have been posted but it doesn't seem to work.
    I have a Technosat receiver T-888
    The system information is H/W CAS-3520433
    S/W CASSMIX-v5.2
    Loader FTA-BL-v2.0
    Updated sep 8 2005
    Is there a patch that I have to put in? If so, how do I do it?
    Any help would be greatly appreciated, many thanks
    Tunaman
    Jun 2006
    i thnk u should check to see whether ur reciever is using the same encryption that the provider requires. if thats ok then u might want to check whether there are any old codes which might be stopping the channel to work.
    netbus
