    Jun 2006
    Default I need help as I am completely useless!!
    You have to admit, when it's true correct? I have a TechnoSat T-888. Recently I have lost all the programs that I watch, BBC (both) Multivision (all), Motors TV, and horrifyingly, Spice Platinum. I need help, and I'm completely new to Satelite receivers, so if you can help, please explain as if to a child (which I'm not - I'm 34 years old)
    Thanks in advance
    Tunaman :P
    try 10911.00MHz-Vertical for your spice platinum channel. BBC is also using the AES keys, imho so update them accordingly. as for motorstv, i cannot answer that.
    Jun 2006
    Default Thanks... But....
    Many thanks Bok_noy, but as I said, I have no clue what that means. Do I go to the Channel and try to adjust or do I go the the Manual edit and do from there? What do I do, this is the first time that I have even gone into my satelite settings - never seen them before, all looks very confusing!
    Lahore
    Default Re: I need help as I am completely useless!!
    Quote Originally Posted by Tunaman
    Thanks in advance
    Tunaman :P
    Welcome to RDI Tunaman
    Motors TV is still working on ABsat rest all which you mentioned in your post are using AES keys ,,,so plz visit for more info
    http://www.********.com/f2/viewtopic.php?t=44441
    Fte Max 100S
    Humax IRCI-5400z
    go to your menu, satellite settings and select hotbird then look at the transponder list. if you don't find the one i posted, add it manually, do a search and view your channels. it would help a lot if you can mention the receiver you are using so that people may be able to guide you accordingly on what to do.
  1. Replies: 2
    Last Post: 13th September 2006, 18:01
  2. COMPLETELY LOST ... HELP ...TPS KEYS
    By med2 in forum RDI - English
    Last Post: 27th March 2006, 13:52
