Results 1 to 10 of 10
    Jun 2006
    Default Problem getting Horizontal signals from PAS 10
    Hi I am having problem receiveing Horizontal signals (PAS10) but vertical signals r fine and sometimes it the opposite, i get the channels on horizontal signals but not on vertical and 2 more ppl r sharing from the same LNB.
    Can ne1 suggest wat i can do?
    Africa-Kenya-Nbi
    If two more people are sharing, it means all of the three can only get H or v at the same time an lnb can not process V an H at the same time, so if one receiver has switched v you cannot get h on your receiver.
    Let only one receiver power and control the polarity then the others should depend on that one.
    Dstv HD PVR
    Jun 2006
    Thank for the reply but i think i'll install another dish for PAS 10...tc
    Aug 2004
    i thought c BAND can be split any no of times. I do get pas 10 one reciever H and one reiver V
    Jun 2006
    Even i get both V & H channels on my reciever but some times only H or V...i'll install a seperate Dish n check it out
    Africa-Kenya-Nbi
    Quote Originally Posted by rishi
    I tried while using one downlead, but couldnt work for me.
    tell me the system u used.
    mine is lnb to 1st rcvr then out to second, then out of second to third.
    once the first receiver is set to V all must use v and vise versa.
    Dstv HD PVR
    Aug 2004
    Dont use loop connections, Use a 2 way splitter from the lnb and then connect the 2 recievers with separate wires. Then V and H both work
    Africa-Kenya-Nbi
    thanks rishi will try it yourway
    Dstv HD PVR
    az30094
    Technically, sharing of lnbs is not possible. It may seem to be working, but may cause damage to your equipment. You have an option to use multi-output lnbs if you want to connect your dish to more than one receivers.
    Africa-Kenya-Nbi
    Quote Originally Posted by az30094
    i wonder whether we have multi output lnbs for c band, havent seen one yet,
    even i hear of the c and ku combi but havent managed to secure one.
    Dstv HD PVR
  1. VERTICAL "OR" HORIZONTAL SIDE DEAD OF LNB'S
    Last Post: 14th November 2006, 09:25
  2. Signals ZERO
    By sidnoor in forum RDI - English
    Last Post: 15th June 2006, 01:19
  3. UHF Signals and A/V Signals?
    By hummy in forum RDI - English
    Last Post: 10th March 2006, 16:10
  4. Signals weak
    By thevar in forum RDI - English
    Last Post: 15th November 2005, 14:18
  5. FTA signals
    By JPS in forum RDI - English
    Last Post: 30th August 2005, 06:00
