Results 1 to 15 of 21
    waterford/ireland
    Default please help,what is j tag for?
    i have a circuit diagram for a j tag,which would be quite easy to solder up,however , what would it be used for?what does it do?how would it be connected to what?please help
    Chennai, India
    You can connect the Jtag, in your receiver's Jtag slot. It is used to flash (program) your receiver.
    95° East
    Regards
    May 2004
    Dear Anver, in your links thats is not the J-Tag for receivers, it is something else.
    a JTag is a cusome designed elctronic circuit to get your Receivers flash programmed, It is helpfull when receiver is dead or due to any other reason you can not program a receiver on its Parallel/printer port. That is when a jtag is used.
    Normaly a jtag is a small circuit board and it connects to your PC's rs-232/serial port and inside the receiver on its ciruit board.
    95° East
    Dear Saed,
    Yes that is all about JTAG and that is correct as well, ''PROGRAMME A CIRCUIT BOARD", but you explained in a simple mode, and that is the same you quoted on your reply - used for a dead receiver or due to any receiver.
    Regards
    May 2004
    ok thanks dear anver
    nundry
    Lahore
    Quote Originally Posted by saed
    nundry
    @Anver
    translate plz
    Fte Max 100S
    Humax IRCI-5400z
    95° East
    Shukriya - Hindi
    Nundri - Tamil
    Dhanyawadalu - Telugu
    Nandi - Malayalam
    Shukran - Arabic
    Deu Borem Karu - Goan
    Merci - French
    Abhari Ahut - Maratti.
    tired man.............
    Regards
    Lahore
    Quote Originally Posted by Anver
    Shukriya - Hindi
    Nundri - Tamil
    Nandi - Malayalam
    Shukran - Arabic
    Merci - French
    Thanks for detail but I want to know in Punjabi
    Fte Max 100S
    Humax IRCI-5400z
    95° East
    tired man............. Thanks for detail but I want to know in Punjabi
    As I said - tired man - next time.
    Regards
    May 2004
    Gracias - spanish
    multumesc - romanian
    Shie Shie - Chinese
    Koma wo yo - Korean
    terimakasih - indonesain/malaysian
    matur suwun - Jawa (indonesian local language)
    Hatur nuwun - Sunda (indonesian local language)
    need more ?
    95° East
    Dear
    Gr8 man - Infact Masood is looking for something in Punjabi.
    Regards
    May 2004
    in Punjabi i think it is Kirpa or Kiripia
    21.95° N 97.06° E
    Here is some information about JTag & Jkeys.Contribute from Sir Farukh Kahawagi...
    During Upgrade If ur Receiver Dead
    Or If U facing any Problem In Ur Receiver u can use JTag.
    jKeys is a program primarily used to access memory on IRDs. It works by utlizing processor diagnostic devices via the JTAG port. This software has been used on STMicroelectronics STiXXXX (ST20 based core) and LSI SC2000 processors.
    jtag Works With,
    IRD, 1, "2700", 1, 1, 1, 1, 2, 2, 0x7FFFFFC0, 0x7FFFFFC4, 0x7FFFFFA0, 0x7FFFFFA8, 0x7FFEFFC4, 0x7FFEFFC8, "10G", 1, 1
    IRDFlash, 1, "Flash 1(29F400)", 0x2223, 0x7FF80000, 0x80000, 2, 2, 0
    IRD, 2, "2800", 1, 1, 1, 1, 2, 2, 0x7FFFFFC0, 0x7FFFFFC4, 0x7FFFFFA0, 0x7FFFFFA8, 0x7FFEFFC4, 0x7FFEFFC8, "11R", 1, 1
    IRDFlash, 2, "Flash 1(29F400)", 0x2223, 0x7FF80000, 0x80000, 2, 2, 0
    IRD, 3, "3700", 1, 1, 1, 1, 2, 2, 0x7FFFFFC0, 0x7FFFFFC4, 0x7FFFFFA0, 0x7FFFFFA8, 0x7FFEFFC4, 0x7FFEFFC8, "10G", 1, 1
    IRDFlash, 3, "Flash 1(29F400)", 0x2223, 0x7FF80000, 0x80000, 2, 2, 0
    IRD, 4, "3800", 1, 1, 1, 1, 2, 2, 0x7FFFFFC0, 0x7FFFFFC4, 0x7FFFFFA0, 0x7FFFFFA8, 0x7FFEFFC4, 0x7FFEFFC8, "10L", 1, 1
    IRDFlash, 4, "Flash 1(29LV160)", 0x22C4, 0x7FE00000, 0x200000, 2, 2, 0
    IRD, 5, "3900", 1, 1, 1, 1, 2, 2, 0x7FFFFFC0, 0x7FFFFFC4, 0x7FFFFFA0, 0x7FFFFFA8, 0x7FFEFFF4, 0x7FFEFFF8, "11L", 1, 1
    IRDFlash, 5, "Flash 1(29LV160)", 0x22C4, 0x7FE00000, 0x200000, 2, 2, 0
    IRD, 6, "4700", 1, 1, 1, 1, 2, 2, 0x7FFFFFC0, 0x7FFFFFC4, 0x7FFFFFA0, 0x7FFFFFA8, 0x7FFEFFC4, 0x7FFEFFC8, "10H", 1, 1
    IRDFlash, 6, "Flash 1(29LV160)", 0x22C4, 0x7FE00000, 0x200000, 2, 2, 0
    IRD, 7, "4900", 1, 1, 1, 1, 2, 2, 0x7FFFFFC0, 0x7FFFFFC4, 0x7FFFFFA0, 0x7FFFFFA8, 0x7FFEFFF4, 0x7FFEFFF8, "11H", 1, 1
    IRDFlash, 7, "Flash 1(29LV160)", 0x22C4, 0x7FE00000, 0x200000, 2, 2, 0
    IRD, 8, "501-5100", 6, 3, 1, 1, 2, 2, 0x7FFFFFC0, 0x7FFFFFC4, 0x7FFFFFA0, 0x7FFFFFA8, 0x7FFDFFF4, 0x7FFDFFF8, "10S", 3, 4
    IRDFlash, 8, "Flash 1(U6-29DL323)", 0x2250, 0x7F800000, 0x400000, 2, 2, 0
    IRDFlash, 8, "Flash 2(U7-29DL323)", 0x2250, 0x7FC00000, 0x400000, 2, 2, 0
    IRD, 9, "301-3100", 7, 3, 1, 1, 2, 2, 0x7FFFFFC0, 0x7FFFFFC4, 0x7FFFFFA0, 0x7FFFFFA8, 0x7FFDFFF4, 0x7FFDFFF8, "10E", 3, 4
    IRDFlash, 9, "Flash 1(U10-M29W160)", 0x22C4, 0x7FC00000, 0x200000, 2, 2, 0
    IRDFlash, 9, "Flash 2(U11-M29W160)", 0x22C4, 0x7FE00000, 0x200000, 2, 2, 0
    IRD, 10, "6000", 3, 4, 1, 1, 2, 4, 0x7FFFFFC0, 0x7FFFFFC8, 0x7FFFFFA0, 0x7FFFFFA8, 0x7FFDFFF4, 0x7FFDFFF8, "12N", 4, 2
    IRDFlash, 10, "Flash 1 Hi(U45-29LV160)", 0x22C4, 0x7FC00000, 0x200000, 2, 4, 2
    IRDFlash, 10, "Flash 2 Lo(U41-29LV160)", 0x22C4, 0x7FC00000, 0x200000, 2, 4, 0
    IRD, 11, "301-3100", 11, 2, 1, 2, 2, 2, 0x1FC0FFF0, 0x1FC0FFF4, 0x1FC0FFC0, 0x1FC0FFC8, 0x1FFEFFF4, 0x1FFEFFF8, "10U", 1, 3
    IRDFlash, 11, "Flash 1(IC22-29LV160)", 0x2250, 0x1FE00000, 0x200000, 2, 2, 0
    IRDFlash, 11, "Flash 2(IC23-29LV160)", 0x2250, 0x1FC00000, 0x200000, 2, 2, 0
    IRD, 12, "DRD420RE", 1, 1, 2, 1, 2, 2, 0, 0, 0, 0, 0, 0x5000003D , "XXX", 3, 1
    IRDFlash, 12, "Flash 1(28F160)", 0xd0, 0x50000000, 0x200000, 2, 2, 0
    IRD, 13, "DRD43x", 7, 1, 2, 1, 2, 2, 0, 0, 0, 0, 0, 0x5000003D , "XXX", 5, 4
    IRDFlash, 13, "Flash 1(M29W320DB)", 0x22CB, 0x7FC00000, 0x400000, 2, 2, 0
    IRDFlash, 13, "Flash 2(28F320J3A)", 0x16, 0x7FC00000, 0x400000, 2, 2, 0
    IRDFlash, 13, "Flash 3(M28W320CB)", 0x88BB, 0x7FC00000, 0x400000, 2, 2, 0
    IRD, 14, "DRD220", 1, 1, 2, 1, 2, 2, 0, 0, 0, 0, 0, 0x5000003D , "XXX", 2, 1
    IRDFlash, 14, "Flash 1(28F160)", 0xd0, 0x50000000, 0x200000, 2, 2, 0
    IRD, 15, "DRD43x MVB-X", 8, 1, 2, 1, 2, 2, 0, 0, 0, 0, 0, 0x5000003D , "XXX", 5, 4
    IRDFlash, 15, "Flash 1(M28W320CB)", 0x88BB, 0x7FC00000, 0x400000, 2, 2, 0
    IRD, 16, "DXD426RD(1Chip-GLA)", 1, 1, 2, 1, 2, 2, 0, 0, 0, 0, 0x7FE00035, 0x7FE0003B , "GLA", 2, 1
    IRDFlash, 16, "Flash 1(28F160)", 0xd0, 0x7FE00000, 0x200000, 2, 2, 0
    IRD, 17, "DXD426RD(2Chip-GLA)", 1, 1, 1, 1, 2, 2, 0, 0, 0x7FFFA653, 0, 0x7FE00032, 0x7FE00038 , "GLA", 2, 1
    IRDFlash, 17, "Flash 1(28F160)", 0xd0, 0x7FE00000, 0x200000, 2, 2, 0
    IRDFlash, 17, "Flash 2(28F800)", 0x889d, 0x50000000, 0x100000, 2, 2, 0
    IRD, 18, "DXD436RE(2Chip-GLA)", 1, 1, 2, 1, 2, 2, 0, 0, 0, 0, 0x7FE00037, 0x7FC0003D , "GLA", 2, 1
    IRDFlash, 18, "Flash 1(28F320J3A)", 0x16, 0x7FC00000, 0x400000, 2, 2, 0
    IRDFlash, 18, "Flash 2(28F800)", 0x889d, 0x50000000, 0x100000, 2, 2, 0
    IRD, 19, "DXD506RA(2Chip-GLA)", 1, 1, 1, 1, 2, 2, 0, 0, 0x7FFFA653, 0, 0x7FE00034, 0x7FE0003A , "GLA", 2, 1
    IRDFlash, 19, "Flash 1(28F160)", 0xd0, 0x7FE00000, 0x200000, 2, 2, 0
    IRDFlash, 19, "Flash 2(28F800)", 0x889d, 0x50000000, 0x100000, 2, 2, 0
    IRD, 20, "COMAG", 8, 1, 1, 1, 2, 2, 0x7FE00000, 0x7FFFFFC4, 0x7FFFFFFE, 0x7FFFFFA8, 0x7FF74FF4, 0x7FFEFFC7, "Fre", 0, 0
    IRDFlash, 20, "Flash 1(39VF160)", 0x2782, 0x7FE00000, 0x200000, 2, 2, 0
    IRD, 21, "DSI22", 1, 1, 1, 1, 2, 2, 0x7FFFFC50, 0x7FFFFC54, , , 0x7FFFFC01, , "501", 3, 1
    IRDFlash, 21, "Flash 1(AM29LV160)", 0x22C4, 0x7FE00000, 0x200000, 2, 2, 0
    IRDFlash, 21, "Flash 2(AM29LV800)", 0x22DA, 0x60000000, 0x100000, 2, 2, 0
    IRD, 22, "DSI23", 1, 1, 1, 1, 2, 2, 0x7FFFFC50, 0x7FFFFC54, , , 0x7FFFFC01, , "502", 3, 1
    IRDFlash, 22, "Flash 1(TC58FVT160)", 0xC2, 0x7FE00000, 0x200000, 2, 2, 0
    IRDFlash, 22, "Flash 2(TC58FVT800)", 0x4F, 0x60000000, 0x100000, 2, 2, 0
    IRDFlash, 22, "Flash 3(AM29LV160)", 0x22C4, 0x7FE00000, 0x200000, 2, 2, 0
    IRDFlash, 22, "Flash 4(AM29LV800)", 0x22DA, 0x60000000, 0x100000, 2, 2, 0
    IRD, 23, "DSI30", 1, 1, 1, 1, 2, 2, 0x7FFFFC60, 0x7FFFFC64, , , 0x7FFFFC01, , "506", 3, 1
    IRDFlash, 23, "Flash 1(E28F320J3A)", 0x16, 0x7FC00000, 0x400000, 2, 2, 0
    IRD, 24, "FS-LifeTime", 8, 1, 1, 1, 2, 2, 0x7FE00000, 0x7FFFFFC4, 0x7FFFFFFE, 0x7FFFFFA8, 0x7FF74FF4, 0x7FFEFFC7, "Fre", 0, 0
    IRDFlash, 24, "Flash 1(39VF800A)", 0x2782, 0x7FF00000, 0x100000, 2, 2, 0
    IRD, 25, "Coship", 8, 1, 1, 1, 2, 2, 0x7FE00000, 0x7FFFFFC4, 0x7FFFFFFE, 0x7FFFFFA8, 0x7FF74FF4, 0x7FFEFFC7, "Fre", 0, 0
    IRDFlash, 25, "Flash NEW(39VF160)", 0x2782, 0x7FE00000, 0x200000, 2, 2, 0
    IRD, 26, "STARSAT", 8, 1, 1, 1, 2, 2, 0x7FE00000, 0x7FFFFFC4, 0x7FFFFFFE, 0x7FFFFFA8, 0x7FF74FF4, 0x7FFEFFC7, "Fre", 0, 0
    IRDFlash, 26, "Flash 150D+(39VF800A)", 0x2781, 0x7FF00000, 0x100000, 2, 2, 0
    IRDFlash, 26, "Flash 200CI+(39VF160)", 0x2782, 0x7FE00000, 0x200000, 2, 2, 0
    IRDFlash, 26, "Flash 1500(LH28F800BVE)", 0x00001, 0x50000000, 0x100000, 2, 2, 0
    IRDFlash, 26, "Flash 1500 NEW(LH28F800BVE)", 0xFFFFF, 0x50000000, 0x100000, 2, 2, 0
    IRD, 27, "Arion 8100E", 16, 1, 1, 1, 2, 2, 0x7FE00000, 0x7FFFFFC4, 0x7FFFFFFE, 0x7FFFFFA8, 0x7FF74FF4, 0x7FFEFFC7, "810", 0, 1
    IRDFlash, 27, "Flash 1(M29W160DT)", 0x90, 0x7FC00000, 0x200000, 2, 2, 0
    IRD, 29, "301-3100 (P17x 2 Flash)", 7, 3, 1, 1, 2, 2, 0x7FFFFF40, 0x7FFFFF44, 0x7FFFBFE0, 0x7FFFFFA8, 0x7FFDFFF4, 0x7FFDFFF8, "10E", 3, 4
    IRDFlash, 29, "Flash 1(U10-M29W160)", 0x22C4, 0x7FC00000, 0x200000, 2, 2, 0
    IRDFlash, 29, "Flash 2(U12-M29W160)", 0x22C4, 0x7FE00000, 0x200000, 2, 2, 0
    IRD, 30, "301-3100 (Single Flash)", 7, 3, 1, 1, 2, 2, 0x7FFFFF40, 0x7FFFFF44, 0x7FFFBFE0, 0x7FFFFFA8, 0x7FFDFFF4, 0x7FFDFFF8, "10E", 3, 4
    IRDFlash, 30, "Flash 1(U12-M29W320DT)", 0x22CA, 0x7FC00000, 0x400000, 2, 2, 0
    IRD, 31, "301.13 (Changed Amd Flash)", 7, 3, 1, 1, 2, 2, 0x7FFFFF40, 0x7FFFFF44, 0x7FFFBFE0, 0x7FFFFFA8, 0x7FFDFFF4, 0x7FFDFFF8, "10E", 3, 4
    IRDFlash, 31, "Flash (1U-12AM29LV320DT)", 0x22F6, 0x7FC00000, 0x400000, 2, 2, 0
    IRD, 32, "301.13 (REPLACED Amd Flash)", 7, 3, 1, 1, 2, 2, 0x7FFFFF40, 0x7FFFFF44, 0x7FFFBFE0, 0x7FFFFFA8, 0x7FFDFFF4, 0x7FFDFFF8, "10E", 3, 4
    IRDFlash, 32, "Flash (1U-12AM29LV320DT)", 0x22F9, 0x7FC00000, 0x400000, 2, 2, 0
    IRD, 33, "301-013 (1-chip TSOP)", 8, 3, 1, 1, 2, 2, 0x7FFFFF40, 0x7FFFFF44, 0x7FFFBFE0, 0x7FFFFFA8, 0x7FFDFFF4, 0x7FFDFFF8, "10E", 3, 4
    IRDFlash, 33, "Flash 1(U12-M29W320DT)", 0x22CA, 0x7FC00000, 0x400000, 2, 2, 0
    IRD, 34, "SAMSUNG_9500", 1, 1, 1, 1, 2, 2, 0x7FFFFFC0, 0x7FFFFFC4, 0x7FFFFFA0, 0x7FFFFFA8, 0x7FFEFFF4, 0x7FFEFFF8, "11H", 1, 1
    IRDFlash, 34, "Flash 1(FULL)", 0x22C4, 0x7FE00000, 0x200000, 2, 2, 0
    IRDFlash, 34, "Flash 1(FIRMWARE)", 0x22C4, 0x7FE00000, 0x1DFFFF, 2, 2, 0
    IRDFlash, 34, "Flash 1(LOADER)", 0x22C4, 0x7FFE0000, 0x1FFFF, 2, 2, 0
    IRD, 35, "LAZER 2003CX", 1, 1, 1, 1, 2, 2, 0x7FFFFFC0, 0x7FFFFFC4, 0x7FFFFFA0, 0x7FFFFFA8, 0x7FFEFFF4, 0x7FFEFFF8, "11H", 1, 1
    IRDFlash, 35, "Flash 1(FULL)", 0x22C4, 0x7FE00000, 0x200000, 2, 2, 0
    IRD, 36, "supermax9950st", 8, 1, 1, 1, 2, 2, , , , , , 0x7ff0000b, "Fre", 0, 0
    IRDFlash, 36, "TE28F160C3T", 0x88c2, 0x7FE00000, 0x200000, 2, 2, 0
    IRD, 37, "sunny4010", 17, 1, 1, 1, 2, 2, , , , , , , "Fre", 0, 0
    IRDFlash, 37, "TE28F800C3T", 0x88C0, 0x7FF00000, 0x100000, 2, 2, 0
    IRD, 38, "acc9800", 1, 1, 1, 1, 2, 2, , , , , , , "Fre", 0, 0
    IRDFlash, 38, "TE28F800B3T", 0x8892, 0x7FF00000, 0x100000, 2, 2, 0
    IRD, 39, "deawoo9230", 8, 1, 1, 1, 2, 2, , , , , , , "Fre", 0, 0
    IRDFlash, 39, "29LV800T", 0x22DA, 0x7FF00000, 0x100000, 2, 2, 0
    IRD, 40, "REX3000", 8, 1, 1, 1, 2, 2, , , , , , , "Fre", 0, 0
    IRDFlash, 40, "M29W800AT", 0xd7, 0x7FF00000, 0x100000, 2, 2, 0
    IRD, 41, "vision9800", 8, 1, 1, 1, 2, 2, , , , , , , "Fre", 0, 0
    IRDFlash, 41, "39vf800A", 0x2781, 0x7FF00000, 0x100000, 2, 2, 0
    IRD, 42, "next5000", 8, 1, 1, 1, 2, 2, , , , , , , "Fre", 0, 0
    IRDFlash, 42, "M28W160CT", 0x88CE , 0x7Fe00000, 0x200000, 2, 2, 0
    Jtag Spports the
    FlashMfg, 0x01, "AMD"
    FlashMfg, 0x1F, "ATMEL"
    FlashMfg, 0x04, "FUJITSU"
    FlashMfg, 0x20, "STMicro"
    FlashMfg, 0x89, "Intel"
    FlashMfg, 0x98, "Toshiba"
    FlashMfg, 0xAD, "Hynix"
    FlashMfg, 0xB0, "Intel"
    FlashMfg, 0xBF, "SST"
    FlashMfg, 0x00000, "Sharp"
    " 李俊明 Born To Help People "
    Jun 2006
    Riyadh
    i also wants to know more about jtag. motorbud120, can you send me a copy of jtag circuit diagram. my email is [email protected]. thanks.
