    Aug 2004
    Default Disecq Question pls help!
    I have 4 satellite connections to my disecq namely Nilesat/Hotbird/Asiasat3s/Panamsat 7,10
    My problem is whenever i put C band satellites in my disecq it causes problems, Nilesat works properly in any condition but Hotbird then doesnt show any signal strenght, after i remove panamsat or asiasat hotbird works fine.
    what is the problem
    waterford/ireland
    Default diseq 4 into 1
    it sounds as if you need to go into antenna set up menu,and make sure
    c band lnb is selected,together with the correct tone burst,for example
    tone A,universal lnb,hotbird
    tone B,universal lnb,nilesat
    tone C,cband lnb [desired sat]
    tone D ,universal lnb,[another sat]
    hope i`ve helped
    Pakistan
    Dear friends
    i m facing the same prob. in addition to the reduction in the percentage of signal in Ku LNB
    Help is requested please.
    az30094
    Default Re: Disecq Question pls help!
    Quote Originally Posted by rishi
    what is the problem
    My configuration is also a mix of Ku band and C band lnbs, and am not facing any problems. You have two Ku band and two C band dishes - should not matter as long as you have configured your settings correctly.
    By the way, make sure no other receiver or device is connected to your diseq. Digital satellite system does not permig sharing equipment without problems.
    i suspect a faulty switch not properly going back to the ku band from c. try changing to a better quality diseqc switch.
  1. disecq conserva???
    By gavrild in forum DTH & Cable-Romania
    Last Post: 14th August 2006, 01:16
  2. DiSECQ Configuration
    By shoko in forum RDI - English
    Last Post: 26th February 2006, 15:56
  3. SS2.6b+DisecQ=?
    By Rely in forum Placi DVB
    Last Post: 3rd November 2005, 23:43
  4. schema disecq
    By Banan6ro in forum Placi DVB
    Last Post: 15th May 2005, 18:07
  5. Intrebare Disecq -PC
    By poorcku in forum Placi DVB
    Last Post: 26th May 2004, 15:48
