Results 1 to 15 of 18
    Apr 2006
    Default ASIA-SAT3 channels going blank
    Some of the following FTA channels are in blank in my stb for last 2 days. Plz confirm is this normal for others. Or is there any other freq/SR
    Channels are
    Indus TV, Channel G, DW-TV, CCTV4, Channel-V, Arabic MUX etc etc.
    Enjoy while FTA....................
    Lahore
    Default Re: ASIA-SAT3 channels going blank
    Quote Originally Posted by satpalchat1
    Channels are
    Arabic Mux is not watched by me ever ,,but rest all channels are working nicely beside channel V.CCTV4(not checked)
    Fte Max 100S
    Humax IRCI-5400z
    Apr 2006
    Channels are
    Thanks masood for info. what do you think, why this problem occuring for cetain channels. is there any PID,AID change?
    As per you comments, looking like there might be some problem in my STB
    Lahore
    no any type of change occurred...re-tune the frequncies and let me know then
    Fte Max 100S
    Humax IRCI-5400z
    Apr 2006
    Okay, I shall do...........
    Sri Lanka - Hikkaduwa
    all the channels on asiasat 3 are ok.There are no changes.But it seems that you you don't get get the horizontal polarized channels.
    Check with a Voltmeter if the Voltage switching is working.
    For vertical you should have 13V and for horizontal 18V.
    If this is OK your LNB might be defect.Anyhow - what is your LNB?
    Kaefi
    Apr 2006
    Quote Originally Posted by Hikkaduwa
    Thanks for valuable info regarding LNB. Its true all "H" polarity gone-off.
    By the way, I have set-up of 4-1 Disq switch in between STB & LNBs (2-Ku, 1-C band). Do you think problem is in the switch? or where I can check such voltage requirement?
    Or where will possible checking point/s?
    I shall confirm you regarding LNB later on.
    cheers
    Nov 2003
    United Arab Emirates
    cheers
    one more thing add please check if someone else take connection form your dish this also effect on it
    Apr 2006
    Quote Originally Posted by dodi
    cheers
    Thats not possible, dish is inside my property. My doubt is Voltage or loose connection.
    Let see what it would be.
    21.95° N 97.06° E
    Hi satpalchat1 , take off AS 3S cable from Diseq and put direct into ur receiver.If all H/V channels r back, ur Diseq may be wrong.If still u can't get Horizonal , ur LNB may be game over.
    Hope this will help.
    " 李俊明 Born To Help People "
    Apr 2006
    Quote Originally Posted by yan naing
    Good Suggestion, thanks
    Apr 2006
    Default "H" Polarity not working in my STB
    By the way I could not get chance to do full check as suggest by you guys. But One think I noticed, Ku band "H" polarity working fine. Only C-Band "H" polarity not working.
    Any body faced similar problem before, plz advice me. thanks........
    Your receiver is OK and the Diseq switch too.
    The cable to the C-Band LNB is also OK - or you would even not get the V channels if there is a loose connection.
    So your LNB might be defect - I had the same problem twice earlier.
    If you have LNBF I can recommend Pauxis.
    With this I have the best results and I have tested many other LNBF's like Eurostar,Supermax,Diplosat etc.
    And it is cheap too.I get it in Sri Lanka for approx. 7 U$
    Kaefi
    Lahore
    I agree it is cheaper but not so good as Supermax F LNB
    Fte Max 100S
    Humax IRCI-5400z
    Apr 2006
    Thats my prediction too. I shal let you know the update. BY the way I had gone through Pauxis website, they have following info regarding LNBF.
    I think this is quite useful for SAT users, isn't it?
    "If you are able to receive only the odd or even channels on a given satellite, then your polarizer is defective and need replacement. The polarizer is a motor located on your feedhorn which switches the unit to receive the vertical or the horizontal polarity. Since every time you switch channels the motor moves, eventually it will wear out and will need replacement. It is connected by three wires from the back of your analog receiver to the dish (the wires are normally (Red '5VDC', White 'pulse', and Black 'ground'). Before replacing the polarizer make sure to turn the receiver's power off. It would be prudent to remove the power cable from the electric socket since most receivers continue to provide power to the dish even when the unit is off."
    Cheers..........
  1. ASIA SAT3 KU
    By superia4u in forum RDI - English
    Last Post: 31st May 2010, 18:14
  2. ASIA sat3 ,thaicom2,3 And pas 10
    By shehbaz in forum RDI - English
    Last Post: 23rd May 2009, 06:33
  3. Replies: 3
    Last Post: 4th September 2006, 18:45
  4. Zee TV Asia Pacific, Zee Music Asia and Zee Punjabi on PAS 8
    Last Post: 12th November 2005, 19:05
  5. NEW CHANNELS AT ASIA SAT2
    By gitter in forum RDI - English
    Last Post: 27th September 2005, 12:20
