    Haiduc Expert
    Latitude: 44.202, Longitude: 27.322, Bărăgan City
    Default 1730000 lei TUNER TV/FM KWORLD CONEXANT (DVB S-100)
    Am gasit pe situl ultrapro aceasta placa....o fi ceva de capul ei?
    Este echivalenta SS2?
    http://www.ultrapro.ro/magazin/Afise....y=0&image.x=0
    173,00 RON
    1.730.000 Lei
    Specificatii :
    Model DVB S-100
    Tip Digital Video Satellite TV Card, intern
    Conectori TV Input - 75 Ohm, AV (Composite), S-Video
    Dotari Telecomanda
    Supports real-time digital video recording in MPEG2 format
    EPG Function
    FM record & playback
    S.R.P.O. -Schedule Recording in PC Power-Off Mode
    Still Image capture in JPEG or BMP format
    Interfata PCI 2.2
    Bundle Installation CD,
    Installation Manual,
    DVB-S PLUS User Manual,
    MPEG Converter
    MPEG Editor
    Burn DVD
    Garantie 1 an
    Digitally Remastered Expert
    root
    Dacă nu este o eroare de prezentare (adică să fi pus date de la placă DVB-S şi n realitate să fie vorba despre un tuner TV clasic), oferta pare n regulă. Ţinnd cont de faptul că e vorba de un chipset Conexant, am ndoieli mari. Ct despre compatibilitate cu SS2, nu cred că poate fi vorba. Ar trebui studiat n detaliu, eventual o vizită la ei la magazin.
    Este o placa DVB cred ca despre asta am citit acum vreo 2-3 ani in revista Chip. Dar eu zic ca tot mai bine merita un SS2 care este verificata si verificata.
    Teacher
    Transilvania
    Kworld DVB-S 100 este o placa de receptie DVB-S. Oferta de pe Ultra-Pro pare a fi chiar tentanta.
    Short description: Put the world of FREE satellite television at your fingertips with the KWorld DVB-S Satellite Receiver System. The self contained system includes all the software needed to capture, control, and manipulate the reception, recording, and playback of programs from satellite sources offering free-to-air programming on your PC system plus VCD/DVD burning programs to create hard copies of recorded material. The DVB-S Satellite Receiver System allows you to watch digital satellite TV programs on your PC while turning your PC into a high tech PVR (personal video recorder) to schedule programs to be recorded and watched at a later date.
    Cititi aici:
    http://www.newegg.com/Product/Produc...82E16815100133
    http://www.superwarehouse.com/Kworld...S-100/p/723427
    http://accessories.gateway.com/Acces...040_ProdDetail
    http://gamepro.pricegrabber.com/sear...sterid=8903867
    "The Truth Is Out There"
    timisoara
    @bibbicu....nu stiu ce te chinui...pentru cateva sute de mii in plus iti iei un ss2...care de bine de rau este consacrata.....softuri la zi sunt pentru ea...emu la fel..de ce vrei sa te legi la cap daca nu te doare
    SS2+ECHOSMART 790+H-H+ANTENA1.2
    Timisoara
    are cineva sa testeze daca merg softurile altdvb sau progdvb pe ea?
    Tr. Severin
    Kworld DVB-S are suport in ProgDVB dar nu stiu care model ; acum 3 ani parca aveau modelul ce CI ;
    Conexant ( BT ) 878 este folosit si de un model Pinaclle
    Varianta cam riscanta achizitionarea ei .
    HELL or something like that
    Placa are suport in ProgDvb dar nu in AltDvb. Skynet nu merge cu ea (din cate stiu eu) si are un tuner comparabil cu Skystar2 ca sensibilitate. In plus are intrari video si in minus un program de toata jena care vine cu placa specific Kworld. De preferat Skystar2! Macar esti sigur.
    E o alternativa pentru cei care doresc sa foloseasca 2 placi pe acelasi calculator: un Skystar si un alt model de placa. Preferabila este Avermedia de la Caro. Are tuner mai sensibil si o aplicatie destul de buna + telecomanda si intrari video dar e mai scumpa.
    O placa identica cu Kworld-ul este facuta de Teratec dar n-am vazut-o in ofertele din RO.
    Incepator cu vechime
  1. Kworld dvb-s 100 diseq plugin
    By sorin_tv in forum Placi DVB
    Last Post: 19th March 2006, 13:12
  2. Kworld DVBS-100 pci card keys
    By Davax in forum RDI - English
    Last Post: 7th December 2005, 08:17
  3. Conexant chip receiver
    By alibaba in forum RDI - English
    Last Post: 31st October 2005, 05:12
  4. placa dvb Kworld
    By cipi in forum Placi DVB
    Last Post: 23rd February 2004, 16:24
