Results 1 to 10 of 10
    Jun 2006
    Default can some1 pleez help with entering keys?
    I have a meta box1 with no card. I know how to get into the menu and to the key edit but i dont know which key goes where.
    Someone gave me the new key for the sf channels which are:
    Key 0D:48 0E A5 71 4C 28 99 41
    DEC:072 014 165 113 076 040 153 065
    Now, my question in which no. do i put the key and what is the dec for?
    Jun 2006
    Africa-Kenya-Nbi
    mr kharim.
    the keys are the same, but some in hex, and some in decimals. there are receivers you have to punch decimals on remote to enter the codes, and other receivers you just enter the keys as they are in hex.
    try your luck.
    Dstv HD PVR
    Africa-Kenya-Nbi
    mr kkarim.
    try your luck.
    Dstv HD PVR
    Jun 2006
    Default help needed to enter keys in Hivion 9090x receiver
    could u plz tell me how to enter keys in Hivion 9090x receiver
    May 2004
    @kkarim
    in Key Code menu, Goto Viaccess section, search for key which starts with 009400 or if it is not there add a new one
    and add the key like this
    009400 0D 48 0E A5 71 4C 28 99 41
    just forget about DEC key, it is not for you. it is for cam and devices which use Decimal key format instead of Hex format.
    Jun 2006
    DEAR SAED
    I DON'T KNOW HOW TO ENTER TPS KEY;
    I KNOW THAT I HAVE TO CUT THE ORIGINAL KEY IN TWO KEYS (primaire and secondaire) BUT IN WHICH INDEX 0A OR OB,....etc.
    i have a echostar receiver dci 2200.
    thank you for ur reply
    Default Re: help needed to enter keys in Hivion 9090x receiver
    Quote Originally Posted by dragon_arts
    my friend press menu go to stb setting then press 1234
    good luck..........
    Jun 2006
    dear fsales,
    "my friend press menu go to stb setting then press 1234
    good luck.........."
    dude could u plz eloborate bit more -- im new to this --- in STB setting i need to press 1234 - or i need press any other link before pressing 1234
    dude i need ur help plz
    regards
    Jun 2006
    Default Thanks
    Ok i got it. I think Im starting to get the hang of this. THANKS A LOT to every1 who provided me with replies and information. I would not be able to watch soccer without all of your help.
    MUCH APPRECIATED.
  1. Entering Prem**Re keys
    By czechrite in forum RDI - English
    Last Post: 22nd August 2006, 20:48
  2. B4U Movies (Entering Keys: Help Needed)
    By szohaibs in forum RDI - English
    Last Post: 26th July 2006, 17:15
  3. help entering keys
    By G E R in forum RDI - English
    Last Post: 4th April 2006, 15:14
  4. Entering Keys With Innovia IDS-3088N2
    By SumitB in forum RDI - English
    Last Post: 16th November 2005, 16:12
  5. Entering the keys
    By pahmadi in forum RDI - English
    Last Post: 5th November 2005, 01:13
